Trunk Divider #1334344
11/12/12 03:39 PM
11/12/12 03:39 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Hi Guys,
Finally getting some work done on the 34 after spending all summer on a remodel. I'm working on the trunk divider and I'm wondering if anyone has any ideas as to what material to make it from? I was initially going to use sheet steel but now I'm wondering if I should use something lighter. The obvious next choice would be aluminum or maybe fiberglas sheet. Any other ideas?
Arno
Re: Trunk Divider [Re: B1arno] #1334345
11/13/12 01:27 AM
11/13/12 01:27 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Is this going to be a firewall, or just something to separate the trunk from the interior?
If its not a firewall, I would consider a piece of paneling or particle board. It would have enough strength to stand alone and is easy to add material to cover it up. The original 30s cars used 1/4" plywood. If it will have some reinforcing, a sheet of ABS plastic would work well, it too is easy to attach a material covering, but would probably not have enough strength to stand alone. I used ABS with a sheet metal x brace. Gene
Re: Trunk Divider [Re: poorboy] #1334346
11/18/12 07:53 PM
11/18/12 07:53 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Thanks for your input Poorboy,
As it will be a firewall of sorts I decided on using .050 aluminum. It's installed with Dzus fasteners so I can remove it easily for fuel cell and battery maintenance. Thanks again,
Arno
Re: Trunk Divider [Re: B1arno] #1334347
11/19/12 12:36 PM
11/19/12 12:36 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Very nice Arno
Re: Trunk Divider [Re: B1arno] #1334348
11/19/12 03:41 PM
11/19/12 03:41 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
nice job
I was going to suggest MDF, but I realized I'm late to the party.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Trunk Divider [Re: B1arno] #1334349
11/19/12 10:58 PM
11/19/12 10:58 PM
moparx Offline
moparx  Offline
you do great work arno ! are you sealing that with anything ?
Re: Trunk Divider [Re: moparx] #1334350
11/20/12 11:44 PM
11/20/12 11:44 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Thanks guys! I am sealing the two non-removable sections with 3M strip caulking. The removable sections will not be sealed. The trunk will get upholstered and should help seal it.
The fuel cell and sealed battery box are both vented outside the car. I just installed some remote jumper terminals in the trunk divider because the battery is not readily accessible. This way I can put a battery tender or jump the battery without spending 20 minutes taking the car apart.
Arno
