Switching from Valvoline VR1 to Brad Penn: suggestions?
#1333974
11/11/12 06:58 PM
11/11/12 06:58 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I'm planning on changing the oil in my street/strip 440 (flat tappet) engine in a few weeks and I'm thinking about going with the Brad Penn 15/40W partial synthetic oil. I've never used any partial synthetic oils (previously have used VR1)...anything I should know before making the switch?
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Switching from Valvoline VR1 to Brad Penn: suggestions?
[Re: 1968RR]
#1333977
11/11/12 07:31 PM
11/11/12 07:31 PM
Posts: 7,506 Az
Crizila
Az
Go to a full synthetic such a Royal Purple racing oil - 10W40. You won't need an additive ( zinc built in ). You will be able to run a lower viscosity ( reads less friction loss ) with the same protection and improved heat degradation capabilities.
Fastest 300
[Re: Crizila]
#1333978
11/11/12 09:43 PM
11/11/12 09:43 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Valvoline NFS already has loads of zinc and phosporous. That is my choice.
Leon
