Angle die grinder #133322
10/07/08 08:30 AM
10/07/08 08:30 AM
Third Stone from the Sun
Scotts72Rallye Offline OP
Can anyone recommend a good pneumatic 1/4" angle die grinder? I'm looking for one that will last.
Thanks,
Scott
Re: Angle die grinder [Re: Scotts72Rallye] #133323
10/07/08 08:49 AM
10/07/08 08:49 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Thanks,
Scott
Many may disagree, but I like Harbor Freight. When I can buy a die grinder with 1/4" AND 1/8" collets as well as a few various grinding stones for often less than $15 or just the 1/4" die grinder for $9, I don't worry about it lasting. HF has a pretty good return policy and I have yet to wear one out. Trick is a good compressor and to get the grinders when they are on sale and get as many as bits you will use. I actually have 4 or 5 with various bits, rasps, and stones so I don't have to keep changing them. HF abrasives aren't the best but that's where you want to spend your money anyway. I try to get carbide cutting bits when I can afford them. Well worth their cost!
Re: Angle die grinder [Re: Scott Carl] #133324
10/07/08 09:11 AM
10/07/08 09:11 AM
Thanks for your response Scott. Anyone else out there have one they would recommend or steer clear of?
Scott
Re: Angle die grinder [Re: Scotts72Rallye] #133325
10/07/08 09:28 AM
10/07/08 09:28 AM
Tulsa, OK
73cudaproject Offline
Tulsa, OK
Since my welding skills are not so great I end up doing more grinding than I care to admit. Typically I use the 4.5" grinder; however recently my son won a small air powered angle grinder. I think it is the Chicago Pneumatic. I ended up buying a couple carbide tips for this tool and have been amazed at how helpful this tool has been for getting into tight areas. Lots of my grinding has been under the car so my advice is to use the tyvek type suits otherwise the metal shavings will get all over you. I have a few t-shirts I might as well throw away as I cannot seem to get the metal shavings out of the shirt.
To answer your question while I am not a big fan of the electrically operated HF tools I do like the HF air powered specialty tools like the small saw, nibbler, and angle grinder.
Re: Angle die grinder [Re: 73cudaproject] #133326
10/07/08 10:53 AM
10/07/08 10:53 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have a lot of BIG name air tools at work. Mac and Ingersol mostly.
My Die grinder, Cheap. Hasn't let me down yet and I've had it for about ten years noe. Some air tools you don't want to skimp on. IMHO, I don't thnk this is one of those cases.
Good bits and abrasives are worth their cost though
Re: Angle die grinder [Re: 73cudaproject] #133327
10/07/08 11:07 AM
10/07/08 11:07 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Don't want to get too far off the subject, but I do have 2 HF 4" electric grinders and I love them I bought them on sale for $14 each. There again I have a different disc on each to save on tool changing. I use mine a lot but not every day 8 hours a day. I've had them for 3 years now without a problem. I know there's better product out there but I feel these $14 grinders run smother than my $50 Makita and the switch is worn out on that after 3 or 4 years of the same type of use. Just MHO FWIW. I will NOT however scrimp on hand tool such as wrenches an the like. Craftsman, Snap-on, Mac, Matco, etc. Only
Re: Angle die grinder [Re: Scott Carl] #133328
10/07/08 06:36 PM
10/07/08 06:36 PM
Thanks for all the responses! Sounds like everyone so far is happy with the cheap ones.
Scott
Re: Angle die grinder [Re: Scotts72Rallye] #133329
10/07/08 07:00 PM
10/07/08 07:00 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Scott
NOT me! That Harbor Freight grinder is junk in my opinion. I bought it to keep at home used it once and it broke, got another and it has problems with the air valve and handle bending around it! I gave up on trying to get another. It's the bottom in the pic. The top is a Ingersoll Rand 301 it' a few years old now and it was for my wharehouse box. The middle unit is a OLD mac tools that I've had for 16 years in my box at work and use it about every day!! It is a dead ringer for that newer Ingersoll, guess who must have made them for Mac, it just has a different handle. These two grinders are GREAT and a Ingersoll will give years of use.
Re: Angle die grinder [Re: rrunner] #133330
10/07/08 08:42 PM
10/07/08 08:42 PM
Scott
NOT me! That Harbor Freight grinder is junk in my opinion. The middle unit is a OLD mac tools that I've had for 16 years in my box at work and use it about every day!! It is a dead ringer for that newer Ingersoll, guess who must have made them for Mac, it just has a different handle. These two grinders are GREAT and a Ingersoll will give years of use.
I keep seeing some used Snap-on's and Mac's On eBay for under $75.Anyone else have a favorite?
Scott
Re: Angle die grinder [Re: Scotts72Rallye] #133331
10/07/08 08:52 PM
10/07/08 08:52 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Scott
Scott
There is a new ingersoll 301 for $55 buy it now on e bay now. I typed in ingersoll 301 and it was the first to pop up.
Auction # is 230296808005
Just found another for $43!!!! auction 150253512624
Re: Angle die grinder [Re: Scotts72Rallye] #133332
10/07/08 09:25 PM
10/07/08 09:25 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
Ingersoll Rand, but then again I am very partial to them.(worked for them for 12 years now). I also have a Campbel haufeild and it works good for occasional use.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Angle die grinder [Re: rrunner] #133333
10/08/08 10:53 AM
10/08/08 10:53 AM
Thanks John for the heads up on the Ingersoll.
Scott
Re: Angle die grinder [Re: Scotts72Rallye] #133334
10/08/08 11:27 AM
10/08/08 11:27 AM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
I have a cheap Harbour Freight angle grinder that a friend gave me. Before I put togather my new compressor I ran it on a small compressor and line. My shop is now plumed with 3/4" main line and 1/2" drops and hose reels with 1/2" lines on them. I can tell you for a fact that the line size makes a big differnce, and yes you have a compressor capable of supplying enough air. My cheap grinder is a different animal now. Will it last as long as the higher end stuff? Most likely not, but I'll use until it wears out then look at some of the IR stuff.
Re: Angle die grinder [Re: Scotts72Rallye] #133335
10/09/08 04:26 AM
10/09/08 04:26 AM
SE MI
Duster499 Offline
Duster499  Offline
SE MI
Any air tool will last much longer if it is oiled before each use. Get some oil made for air tools and put a few drops in the air inlet before using. I've used Ingersoll, Chicago Pneumatic and Jet all with good results as long as they are oiled regularly.
Re: Angle die grinder [Re: Scotts72Rallye] #133336
10/09/08 08:17 AM
10/09/08 08:17 AM
NW 'Burbs Chicago, IL
A_Roldan Offline
A_Roldan  Offline
I've been using the Harbour Freight one for a couple of months now. No complaints.
It's been working good for me and I agree with the above post; you have to put a few drops of that air tool oil every day before you use your tools. I have had tools for years and years that I oiled daily.
~Angel
Re: Angle die grinder [Re: A_Roldan] #133337
10/09/08 08:44 AM
10/09/08 08:44 AM
Thanks everyone for all the responses. Now that my head is spinning I'll pick something up this weekend.
Scott
Re: Angle die grinder [Re: rrunner] #133338
10/09/08 08:55 AM
10/09/08 08:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Scott
Anyone who say's HF tools are good, have never used a quality tool. That's why Snapon says there is a difference. Because there is and your job will go smoother/faster and will come out better with a quality tool.
Re: Angle die grinder [Re: Challenger 1] #133339
10/11/08 09:19 PM
10/11/08 09:19 PM
5thAve Offline
5thAve  Offline
I have a cheap one and its never had any problems.
Re: Angle die grinder [Re: Challenger 1] #133340
10/11/08 09:34 PM
10/11/08 09:34 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
If you want the best and price is no object,
Dotco.
Re: Angle die grinder [Re: momopar] #133341
10/11/08 09:45 PM
10/11/08 09:45 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
MAC Tools has a two piece set (angle and straight unit) on sale this month for $79.
