Champion RJ12YC too cold for daily driver?
#1332884
11/09/12 07:10 PM
11/09/12 07:10 PM
Posts: 7,052 Madera, CA.
MowP4rsn
Madera, CA.
I figured it's past time to change out my spark plugs that were installed back in '08. Saw some wear on one plug from the passenger bank, some brown deposits building up on passenger bank plugs too. Old plugs that were installed by a shop in '08 were AC Delco 4355, and I was able to get some Champion RJ12YCs off EBay a while back. Just finished installing them (1 hour just to get the rear-most plug on the driver's side , 2 hours to get them all done using hand tools..I don't miss wrenching for a living at ALL ) Anyhoo, think these plugs might be a tad too cool for surface street driving? I'm going to break them in traveling out to a prison 75 miles away that I go to for leading a Bible study tonight, but I figured I'd ask those more knowledgeable on this fine board their opinions...I hope it doesn't break down into this What say y'all?
Re: Champion RJ12YC too cold for daily driver?
[Re: MowP4rsn]
#1332887
11/09/12 11:00 PM
11/09/12 11:00 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
You will be fine. A Champion rep told me the new then (20 years ago or more) RJ12YC plug was designed to cover multi ranges from 10 to 13 or was it 11 to 14?? always worked great for me as did RN12YC in my small blocks.
[Re: MowP4rsn]
#1332891
11/10/12 10:38 AM
11/10/12 10:38 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
RJ12YC is the stock spark plug replacement ( being 11s are not anymore available ). Being a stock replacement, is the correct piece for a driver on a stock engine, even for slightly "tweaked" engine
[Re: RoadRunnerJD]
#1332892
11/10/12 11:16 AM
11/10/12 11:16 AM
Dodgem
Ontario, Canada
That was the point the rep was making the 12 series plugs were redesigned in the late 80's to cover more ranges to make a nice street or street strip plug. I ran 11.13s the last year with iron heads and had run them street strip for 10 years with a 6AL. I would change them out once a season just because at $2 a plug why not.
One year we tried autolite, AC, accel, NKG and Bosch platinum none made improvements the Bosch looked like it had a better street life drove the car on the street till December that year and used them first time out in the spring but they were $6.50 a piece plugs. all plugs ended up being supplied by other racers/freinds when they heard we were doing plug test as they were convinced their plugs were better save for the autolite they were provided by my machinist and pit crew as he spent years to get me to try something else and the bosch we supplied buy a lawnmower shop in the same complex we rented a shop he was a big bosch man and got them special from the rep.
So from early april till early dec all we changed on the car was plugs and oil racing most week ends and driving back and forth to work most weeks!
[Re: Dodgem]
#1332893
11/11/12 10:27 AM
11/11/12 10:27 AM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
12s will be fine, I run 9s in my street car, but I have a hotter ignition. Any hotter and you would probably suffer from pre ignition. They are an extended tip plug that should clean up nicely one on an extended trip. Perfect for daily driver.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
