Mopar Aftermarket Aluminum Valve Covers on 383 #1332686
11/09/12 11:18 AM
11/09/12 11:18 AM
mbperry83 Offline OP
I am trying to install the aluminum Mopar aftermarket valve covers on my 68 barracuda with a 383. I am having a hard time trying to get the passenger side to fit. I think it is hitting the exhaust manifold (stock). Has anyone else had trouble with this? Thanks in advance!
Re: Mopar Aftermarket Aluminum Valve Covers on 383 [Re: mbperry83] #1332687
11/09/12 12:58 PM
11/09/12 12:58 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Might have to drill the holes out a little. Or take a fuzz off the lip if it's hitting the exh. man.
Re: Mopar Aftermarket Aluminum Valve Covers on 383 [Re: mbperry83] #1332688
11/09/12 03:19 PM
11/09/12 03:19 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
Also, sometimes if you use different bolts you gain a little room to shift the cover around.
Re: Mopar Aftermarket Aluminum Valve Covers on 383 [Re: mbperry83] #1332689
11/09/12 04:13 PM
11/09/12 04:13 PM
Canada
demon Offline
demon  Offline
Canada
be prepared for leaks. My buddy used the Mopar aluminum valve covers and found they leaked at the bolts holes because the casting was angled instead of flat.
