Bent axle? #1332057
11/07/12 06:54 PM
11/07/12 06:54 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Installed a new set of moser axles. Drove it for the first time and felt like i have flat tire at right rear... Didnt have this problem until I install axles.
Re: Bent axle? [Re: 416scamp] #1332058
11/07/12 07:58 PM
11/07/12 07:58 PM
Tennessee
meep_meep Offline
meep_meep  Offline
Tennessee
Put a floor jack under the pumpkin, jack it up until the rear wheels are off the ground..then fire it up, stick it in gear and just let it idle....watch each axle turning...if you have a bent one, you will see it...
Re: Bent axle? [Re: meep_meep] #1332059
11/07/12 08:12 PM
11/07/12 08:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I agree but also use stands under the axle to stabilize the car while running. Don't run without someone behind the wheel for safety sake.
Re: Bent axle? [Re: 416scamp] #1332060
11/07/12 08:14 PM
11/07/12 08:14 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What bearings on the old axles , what type on the new ? Did you have trouble getting the axle in and properly seat the bearing in the housing ?
