6BBL power valve blow-out protection #1331686
11/06/12 10:14 PM
11/06/12 10:14 PM
Harrisburg, Pa.
screamindriver Offline OP
Harrisburg, Pa.
Is there a down side to adding the power valve blow-out assembly to the 2300 center carb ???
Re: 6BBL power valve blow-out protection [Re: screamindriver] #1331687
11/06/12 11:32 PM
11/06/12 11:32 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Can't see any. It's just a check valve.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 6BBL power valve blow-out protection [Re: moparmarks] #1331688
11/07/12 10:32 PM
11/07/12 10:32 PM
Harrisburg, Pa.
Harrisburg, Pa.
Thanks Mark.. I'm going to add the kit to a center carb as requested...I remember there was a discussion about the kit somehow changing the vacuum signal {in the 2300 series carb PV circuit} but it's been a while since I was involved in that thread and can't find it...Probably been longer than I'm thinking...The owner wants to add it as a safety measure...I told him if it's tuned correctly you would'nt need it...
Re: 6BBL power valve blow-out protection [Re: screamindriver] #1331689
11/08/12 12:14 AM
11/08/12 12:14 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Been doing 6pk carbs for 35 + years,have yet to find a blown power valve.Only bad ones were those that sat for years and dried up.
