Page 1 of 4 1 2 3 4
Keith Black Block? #1331578
11/06/12 08:10 PM
11/06/12 08:10 PM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
I'm in the process of collecting the parts for my 604ci Hemi. I'm planning on buying a KBRE aluminum block but not sure which block and what options i should get. I know the street hemi block won't work because i need the raised cam, so is it the stage 8 block i need is there anything else i should get done right now. Things after you got yours, you said i should of got this done.
Thanks for any and all info
Kevin
Re: Keith Black Block? [Re: 604 Hemi GTX] #1331579
11/06/12 08:20 PM
11/06/12 08:20 PM
Arizona
Chris'sBarracuda Offline
Arizona
Just call Ken Black.. (562) 869-1518
Go straight to the source...
Chris...
Re: Keith Black Block? [Re: Chris'sBarracuda] #1331580
11/06/12 08:39 PM
11/06/12 08:39 PM
Iowa
coronetville Offline
Iowa
Re: Keith Black Block? [Re: coronetville] #1331581
11/06/12 10:02 PM
11/06/12 10:02 PM
IL
E
EchoSixMike Online content
EchoSixMike  Online Content
E
IL
Or you can email him. Excellent customer response. If I hadn't had a megablock already, I'd have bought a KB. I might still do it, depending on how the economics turn out soon. S/F.....Ken M
Re: Keith Black Block? [Re: EchoSixMike] #1331582
11/06/12 10:30 PM
11/06/12 10:30 PM
ONTARIO,CANADA
ONTARIO,CANADA
Thanks for the replies...I just thought i would ask about the extras that people thought of after they got there blocks.
Kevin
Re: Keith Black Block? [Re: 604 Hemi GTX] #1331583
11/06/12 10:40 PM
11/06/12 10:40 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Make sure you have it drilled for pushrod oiling. It's the only extra cost item I got and happy I did.
Re: Keith Black Block? [Re: Bigcube] #1331584
11/06/12 10:55 PM
11/06/12 10:55 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Then wait until April to get it if you are lucky .Good block ,they just take forever to ship .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Keith Black Block? [Re: Bigcube] #1331585
11/06/12 11:26 PM
11/06/12 11:26 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I didn't have mine done and ended up having it done later. Like Al said talk to Ken and he will go down the order sheet with you. Be prepared to tell him what head you are going to use as the studs come with the block, bore size, deck height, aluminum or steel main caps, o-ring or not, deck finish, and many more. Its also nice to order at least one spare rear main seal. When you get it you are going to join the list of very happy customers.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Keith Black Block? [Re: pittsburghracer] #1331586
11/07/12 12:22 AM
11/07/12 12:22 AM
ONTARIO,CANADA
ONTARIO,CANADA
I just got a reply about time frame and he said 12 weeks. I was thinking around 12 from what everyone was saying, going to order the block at the end of nov when i come home from work.
Kevin
Re: Keith Black Block? [Re: 604 Hemi GTX] #1331587
11/07/12 03:09 PM
11/07/12 03:09 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How much $ we talking here if you don't mind me asking.
Re: Keith Black Block? [Re: 604 Hemi GTX] #1331588
11/07/12 03:22 PM
11/07/12 03:22 PM
CALIFORNIA, USA
KB RACING ENG Offline
CALIFORNIA, USA
Kevin, The KB Street HEMI block is what we would recommend as you can order this with a raised cam location. If you send me an E-mail I will send you the order form that shows all the block options that are available along with a list of some of the more popular HEMI products that we manufacture. Send your E-mail to: kbracing@verizon.net. Thank you for considering our products for your engine build.
Re: Keith Black Block? [Re: cudaman1969] #1331589
11/07/12 03:29 PM
11/07/12 03:29 PM
CALIFORNIA, USA
CALIFORNIA, USA
Cudaman, The KB Street HEMI Blocks start at $5,550. If you send me an E-mail I will send you some information. kbracing@verizon.net. Thank you for asking.
Re: Keith Black Block? [Re: KB RACING ENG] #1331590
11/07/12 03:32 PM
11/07/12 03:32 PM
Delray beach, Florida
P
Performance Only Offline
P
Cudaman, The KB Street HEMI Blocks start at $5,550. If you send me an E-mail I will send you some information. [Email]kbracing@verizon.net.[/Email] Thank you for asking.
Ken, any new word on what we have on order?
machine shop owner and engine builder
Re: Keith Black Block? [Re: 604 Hemi GTX] #1331591
11/07/12 03:52 PM
11/07/12 03:52 PM
an8sec70cuda Offline
For what it's worth, I did not have mine drilled for lifter oil galleys (after talking w/ Ken) and it's been flawless for the 6 years I've been running it. I run a solid roller, but it's not real aggressive. I have it apart for freshening right now and everything looks great.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Keith Black Block? [Re: Performance Only] #1331592
11/07/12 04:47 PM
11/07/12 04:47 PM
CALIFORNIA, USA
CALIFORNIA, USA
Performance Only, Your block is getting close, see attachments. Should be ready to ship in about 2 weeks or less. Main studs and Caps will be installed today to get the block ready for the 4th op on the CNC machine, main line and cam line final machining. There are a couple that are just ahead of yours going through the same process. Sleeves are in process to be installed after the 4th op and then semi finished as per your order form. If you would like more of a detailed up-date please give me a call and I will go over it with you.
Re: Keith Black Block? [Re: KB RACING ENG] #1331593
11/07/12 04:50 PM
11/07/12 04:50 PM
CALIFORNIA, USA
CALIFORNIA, USA
One more.
Re: Keith Black Block? [Re: KB RACING ENG] #1331594
11/07/12 04:52 PM
11/07/12 04:52 PM
PA.
"Little"John
"Little"John
PA.
I wish I had a big blow-up picture of that to hang on my living room wall with all the race car pictures. No home interior crap hanging on our walls
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Keith Black Block? [Re: KB RACING ENG] #1331595
11/07/12 05:56 PM
11/07/12 05:56 PM
Harrison Township, Michigan
Hemi SS Offline
Hemi SS  Offline
What is the weight difference from the Mega block?
Re: Keith Black Block? [Re: pittsburghracer] #1331596
11/07/12 07:04 PM
11/07/12 07:04 PM
organ
maximum entropy Offline
organ
i think i'll take down my tv and put a big print of that block up. stunning.
Re: Keith Black Block? [Re: maximum entropy] #1331597
11/07/12 07:09 PM
11/07/12 07:09 PM
Arizona
Arizona
That's ARTWORK...
Chris..
Page 1 of 4 1 2 3 4
