1969 Big Block Alternator Mounting and Mounting Bracket #1330785
11/04/12 07:11 PM
11/04/12 07:11 PM
Arizona
az426john Offline OP
Arizona
I am trying to help a buddy long distance that is not real experienced install an alternator and mounting bracket on a big block car.
Does anyone have a good illistration or picture that shows how the bracket, spacers and bolts go? I thought I had one, but I don't.
Thanks in advance for you help.
Re: 1969 Big Block Alternator Mounting and Mounting Bracket [Re: az426john] #1330786
11/04/12 11:04 PM
11/04/12 11:04 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: 1969 Big Block Alternator Mounting and Mounting Bracket [Re: gtx6970] #1330787
11/04/12 11:05 PM
11/04/12 11:05 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: 1969 Big Block Alternator Mounting and Mounting Bracket [Re: gtx6970] #1330788
11/04/12 11:41 PM
11/04/12 11:41 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I believe the 69 will have the same "V" bracket?
Re: 1969 Big Block Alternator Mounting and Mounting Bracket [Re: RoadRunnerJD] #1330789
11/04/12 11:45 PM
11/04/12 11:45 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Depends on the model.
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 Big Block Alternator Mounting and Mounting Bracket [Re: Rhinodart] #1330790
11/05/12 01:02 AM
11/05/12 01:02 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Is there any differences between the 66 and older mount bracket without the hole and the one with a hole? Tim
Re: 1969 Big Block Alternator Mounting and Mounting Bracket [Re: gtx6970] #1330791
11/05/12 09:51 AM
11/05/12 09:51 AM
Arizona
Arizona
Many thanks Bill. That diagram with a little guideance should get the job done.
Best regards,
John
Re: 1969 Big Block Alternator Mounting and Mounting Bracket [Re: astjp2] #1330792
11/05/12 10:01 AM
11/05/12 10:01 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The orientation of the parts is exactly the same.
