What kind of a pistons is this? #133010
10/06/08 03:28 PM
10/06/08 03:28 PM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
Hello...
I search the piston or better, where was this piston installed?
4 Notches
two mopar part numbers in it:
3418486
3418631
___________________________ .......plymouth tells it like it is...!
Re: What kind of a pistons is this? [Re: plyrr69] #133011
10/06/08 04:16 PM
10/06/08 04:16 PM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
pls help...
Re: What kind of a pistons is this? [Re: plyrr69] #133012
10/06/08 04:18 PM
10/06/08 04:18 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If thats the piston in the picture in the other thread you were told what it is .
There is only 1 four valve notch piston that was ever used by Chrysler in a 440 .... that I have ever seen , ever
Re: What kind of a pistons is this? [Re: JohnRR] #133013
10/06/08 04:33 PM
10/06/08 04:33 PM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
Here are some pics...
Re: What kind of a pistons is this? [Re: plyrr69] #133014
10/06/08 04:34 PM
10/06/08 04:34 PM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
an other...
Re: What kind of a pistons is this? [Re: plyrr69] #133015
10/06/08 04:36 PM
10/06/08 04:36 PM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
an other one...
Re: What kind of a pistons is this? [Re: plyrr69] #133016
10/06/08 04:37 PM
10/06/08 04:37 PM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
and this...
Re: What kind of a pistons is this? [Re: plyrr69] #133017
10/06/08 04:43 PM
10/06/08 04:43 PM
JohnRR Offline
JohnRR  Offline
stock 6 pk piston , the letter on the top would match a painted letter on the side of the block for measured piston clearance , the factory wasn't to precise when honing the block
Re: What kind of a pistons is this? [Re: JohnRR] #133018
10/07/08 01:12 AM
10/07/08 01:12 AM
dogdays Offline
dogdays  Offline
Greetings in Switzerland!
R.
Re: What kind of a pistons is this? [Re: dogdays] #133019
10/07/08 08:07 PM
10/07/08 08:07 PM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
ok, i will say it to the swiss...
