Re: Bushing the Comp Cams Pro Magnum Rockers [Re: Meangreen68] #1328957
11/01/12 11:44 PM
11/01/12 11:44 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Thanks Autoxcuda for that photo of your Ultra Pro rockers.
Looking at the rocker in your right hand, that looks like a metal-backed sleeve bushing, sintered bronze and PTFE.
Notice the parting line in the bearing.
They look these: http://www.asbbearings.com/steel_backed_bearings.html
And John, you're probably right about those Hughes shafts. Light banana grooves in my shafts is all I probably need to do. It's a hydraulic cam.
My opinion , bananna groove your shafts and run them , you are worrying about nothing if you have a hyd. cam .
edit ... I see that is what you are going to do
Re: Bushing the Comp Cams Pro Magnum Rockers [Re: Meangreen68] #1328958
11/01/12 11:55 PM
11/01/12 11:55 PM
AndyF Offline
AndyF  Offline
You should be okay at 300 lbs spring pressure. Make sure that you have plenty of oil pressure as well as oil flow to the top end.
For a lower speed street engine you might consider grooving the #5 cam journal to provide full time oiling to the top end. You don't want to fill the valve covers up with oil on a race engine, but on a weekend cruiser that doesn't get wound to the redline very often the extra oil can be a good idea.
Re: Bushing the Comp Cams Pro Magnum Rockers [Re: AndyF] #1328959
11/02/12 02:30 AM
11/02/12 02:30 AM
Raleigh, NC
Meangreen68 Offline OP
Raleigh, NC
Thanks Andy.
Having had the lifter bores bushed (bushings drilled w/oil holes), I wonder what difference that makes in regards to the grooving of the cam journal? I imagine it makes available more oil at the mains?
I read a thread where Cab Burge mentions how he meters the oil flow to the heads through carb jets/plugs tapped into the block after he grooves the cam's journal.
Mike at CRE did some oil mods and the cam bearings are installed.
I'm guessing the block will be providing plenty of oil to the heads as it is, without any cam journal grooving.
I deburred the block and smoothed the valley area before shipping it off for machining.
The block came back with the interior painted/coated.
The block is out of the crate, but not on a stand yet
Re: Bushing the Comp Cams Pro Magnum Rockers [Re: Meangreen68] #1328960
11/02/12 11:46 AM
11/02/12 11:46 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
At the spring pressure posted...you won't have any problems without banana grooves or rocker bushings.
They will work fine steel on steel, as long as you do not use any thick, paste-consistancy lubes on the rocker and shaft assy during assembly and do not overtorque (crush) the rocker shafts. Use a liquid type assembly lube only and mind the torque on the hold downs....more is not better....more torque causes galling because it deforms the shaft.
(I have used those rockers at 500lbs open pressure for several years for whatever that's worth, but I have not really put tons of miles on them either)
Rich H.
Esse Quam Videri
Re: Bushing the Comp Cams Pro Magnum Rockers [Re: ZIPPY] #1328961
11/02/12 12:29 PM
11/02/12 12:29 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Comfort levels vary. I wouldn’t be comfortable running that much pressure on a weekend street car — at least with the luck I have.
