Cutting 60' times #1328706
10/30/12 02:58 PM
10/30/12 02:58 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
With all things being the same, how much of an improvement will
you see changing from a 3:23 gear to a 3:91 gear set?
Re: Cutting 60' times [Re: moparmikethree] #1328707
10/30/12 03:06 PM
10/30/12 03:06 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Should give you over .10 in the 60 foot if you don't spin but will improve numbers all the way down the track.
Re: Cutting 60' times [Re: Dodgem] #1328708
10/30/12 03:16 PM
10/30/12 03:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Plus you will raise the cruising rpm by about 600rpm.
Re: Cutting 60' times [Re: moparmikethree] #1328709
10/30/12 05:21 PM
10/30/12 05:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
Maybe none Maybe some Every car is different, the complete package has a lot to do with the results Heavy car that dosen't spin the tires will see some possible benefits, a light weight car that spins the tires with the 3.23 ratio now will problly not see a reduction in the 60 ft times, probally spin worst
Re: Cutting 60' times [Re: Cab_Burge] #1328710
10/31/12 01:19 AM
10/31/12 01:19 AM
South East VA
Joel71 Offline
Joel71  Offline
South East VA
My Satellite will 60 ft within .02 with either a 26" slick or a 28" drag radial and a 3:23 gear. Both hook well so the difference in tire diameter (same as a gear change) is next to nothing. The taller tire has had the best 60 ft. The other thing I see is more MPH with the tall tire. Quarter mile ets are a bit lower with the 28" also. I have run all the following on my car with the same gear and the only real difference is using a sticky tire vs a real street tire.
Real street tires:
215/75-14 (26.5")
235/75-15 (29")
255/60-15 (27")
295/50-15 (26.5")
Sticky race tires:
26X10-15 (26") slick
275/60-15 (28") drag radial
The best time ever...13.06
The worst best time for any of the street tires...13.40
The difference mostly is having a sticky tire that will hook. If all these were the same compound there might be about .03 to .05 between all of them. For my car lower gear hurts it all the way plus I will not have a street car that I can't cruse at 70+ MPH all day in. If it's nothing but a track car that would be different.
Re: Cutting 60' times [Re: moparmikethree] #1328711
10/31/12 08:11 AM
10/31/12 08:11 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I saw a far greater improvement in sixty foot times by using a quality converter (PTC) than changing from 3.23's to 3.91's. Around town fun factor is higher with the 3.91's, freeway driving is less fun. A quality converter will also lower cruising RPM's by a couple hundred.
