Re: world aluminum block question ,valvtrain oiling
[Re: camastomcat]
#1328565
10/30/12 01:57 PM
10/30/12 01:57 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
FWIW my World Aluminum Hemi block came with the block plugs , but they were not drilled. I went with .040" for the Hemi.
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Cab_Burge]
#1328568
10/30/12 03:49 PM
10/30/12 03:49 PM
Posts: 248 Sweden
Tobbe
Sweden
b1 bs heads ,there is 3/8 unc treads in the block oilchannel i have plugs i can drill a hole in the right size and leave the channel oem in the heads i didn get any "jets" whit the block from world
Check the oil passage in the blcock to the heads, my allen head screw in restrictors where in there down near the oil galley passage through the lifter bores, not up near the deck
ok thanks will check that mabey they are deep down there
