Lower Control Arm Bushings.... #1328418
10/29/12 08:03 PM
10/29/12 08:03 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Dropped my LCA's off to have the bushings pressed in... had them picked up today.. does not look like they pressed them in far enough..
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Lower Control Arm Bushings.... [Re: JMCFAN] #1328419
10/29/12 08:10 PM
10/29/12 08:10 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
There is a slight "step" around the pink area there. If it is not touching the bushing, then you're correct. I cannot tell.
Re: Lower Control Arm Bushings.... [Re: buildanother] #1328420
10/29/12 08:42 PM
10/29/12 08:42 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Nothing wrong with them.
Press work was done ok.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Lower Control Arm Bushings.... [Re: hemi71x] #1328421
10/29/12 08:47 PM
10/29/12 08:47 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
OK great thanks. I thought maybe the rib should be flush
Now to assemble
Re: Lower Control Arm Bushings.... [Re: JMCFAN] #1328422
10/29/12 09:00 PM
10/29/12 09:00 PM
hemi71x Offline
hemi71x  Offline
Picture to compare, from a pair of LCA's
