Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: Anyone put a LS in their Mopar yet? [Re: Mr.Yuck] #1328326
10/31/12 11:54 AM
10/31/12 11:54 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
just get it over with and buy ya a beautiful yellow 70 Chevelle or red 73 camaro...
Really if you want different get a new hemi, the prices are pretty good.
Nah, not into 70 Chevelles, or disco Camaros... I just dont see any real future for the new "hemi" If it was so great everyone would put those in Fox Bodys... Again Im a Mopar Guy, but the new Mopars just dont measure up to the new GM products...
Well the GM guys don't measure up to the Furd guys either so why not do a 4.6? Add some boost to your motor if it isn't fast enough for you. If you do go GM make sure you paint your engine bay semi-gloss black, You want the engine to feel at home.
Re: Anyone put a LS in their Mopar yet? [Re: Mr.Yuck] #1328327
10/31/12 12:45 PM
10/31/12 12:45 PM
SO CAL
BB70DUSTER Offline OP
SO CAL
I have to Disagree... the 4.6 isnt nearly as cheap or available as a LS...
Re: Anyone put a LS in their Mopar yet? [Re: 440dart] #1328328
10/31/12 12:48 PM
10/31/12 12:48 PM
SO CAL
SO CAL
If you squeeze 800 hp out of that 2,000 dollar LS, your gonna get a lot of BANG as in KABOOM.
Theres alot of them out there that are proving otherwise... Just adding better rods is taking them even higher...
Re: Anyone put a LS in their Mopar yet? [Re: BB70DUSTER] #1328329
10/31/12 12:52 PM
10/31/12 12:52 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
"Cheap" LS what-evers in my area have 200,000+ miles on them. Hate, what kind of mileage do the $800 LS engines in your area have?
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Anyone put a LS in their Mopar yet? [Re: bigsbigelow] #1328330
10/31/12 01:11 PM
10/31/12 01:11 PM
SO CAL
SO CAL
Most are advertised around 80K-120K... But from my mopar experience the mileage seems to help a bottle motor live... Im gonna try it and find out, I found heads and a mustang to put it in... I have all the nitrous parts already...
Re: Anyone put a LS in their Mopar yet? [Re: BB70DUSTER] #1328331
10/31/12 01:16 PM
10/31/12 01:16 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
For a second i thought i was logged into YB.
Re: Anyone put a LS in their Mopar yet? [Re: BB70DUSTER] #1328332
10/31/12 01:24 PM
10/31/12 01:24 PM
bigsbigelow Offline
bigsbigelow  Offline
I am glad you decided to build the fox body instead of half breeding a Mopar. I too, have been pondering the idea of an LS in a fox body. I even spent yesterday morning searching racing junk for fox bodies with bow-tie power. I found that rolling fox bodies with a cage (I saw lots of bars in the pics) can be had for as little as $2,000. Other rolling stangs with certified or expired cages for E.T.'s as low as 7.5 or 8.5 for under $10,000 with what looked like good paint. Here is an example, stang .
Re: Anyone put a LS in their Mopar yet? [Re: bigsbigelow] #1328333
10/31/12 01:29 PM
10/31/12 01:29 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mopar to the bone!!!
Re: Anyone put a LS in their Mopar yet? [Re: 72Swinger] #1328334
10/31/12 01:56 PM
10/31/12 01:56 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
LS1 9.63 with a 60k mile short block aftermarket heads cam and a carb.If i recall he had somewhere in the range of 12k in the whole car.
Re: Anyone put a LS in their Mopar yet? [Re: 72Swinger] #1328335
10/31/12 05:58 PM
10/31/12 05:58 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
http://www.hotrod.com/techarticles/engine/hrdp_1106_turbocharged_hemi_engine/viewall.html
It's not the engine and parts that cost a lot for swapping them in... it's all the other stuff you need. I thought about the swap into my challenger, but I decided to stick with a stroked 440 and add an od trans. Maybe not as good mpg's but more power for less $ overall.
Re: Anyone put a LS in their Mopar yet? [Re: Silver70] #1328336
10/31/12 07:15 PM
10/31/12 07:15 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Same here, I've done alot of thinking and searching and I've decided my next build will be another super simple BB stroker.
340Rick put a Gen3 Hemi in his Challenger with a stroker kit and a few little upgrades and it went 9.91 right off the bat, that is just awesome but for me and my tight budget I'm just gonna do my old combo again, a simple 400 block, 440 crank(451 cubes), 590 Purpleshaft cam and some Eddy heads, I went 9.80's with this combo and I'll probably detune the next one and drive it everywhere.
Re: Anyone put a LS in their Mopar yet? [Re: ProSport] #1328337
10/31/12 07:47 PM
10/31/12 07:47 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Here's a local guys LS fox body turbo swap.
Re: Anyone put a LS in their Mopar yet? [Re: ProSport] #1328338
10/31/12 08:44 PM
10/31/12 08:44 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I have thought about this swap more than once but looking at it from all the angles I decided I would find a fox mustang or 75 up nova to do it in. Those cars are cheap, can be made light, and suspension parts are abundant/cheap. I have made my BONE STOCK 318 live through 18-19lbs of boost, too much timing, and crappy pumpgas for over a year now and the only problem I have had is a blown head gasket and a cracked piston (piston is still cracked ) Eventually I know it will go out in flaming glory but for $135 at my local yard I can pick up another. For the cost in going to an LS I could build a decent 360 with good rods and pistons and on a conservative tune, still go as fast as I need my street car to be. I like going to local cruise-ins and gathering a crowd to check out my 6 different colored pos, If it had a turbo LS most would pass it by as there are 3 turboed LS cars that come to the same cruise regularly. I'm not a fan of franken-swaps, but I do think the LS platform is the best production engine out there if someone was so inclined. I am still going to a powerglide this winter though
Re: Anyone put a LS in their Mopar yet? [Re: ProSport] #1328339
11/01/12 12:30 AM
11/01/12 12:30 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I think I could or with some help eliminate a lot of the costs... but I'd rather keep it more simple. I originally wanted to do it for the fi and add a turbo, which is not keeping it simple, but I may change my mind again.
Re: Anyone put a LS in their Mopar yet? [Re: Silver70] #1328340
11/01/12 08:47 AM
11/01/12 08:47 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
I wouldn't put one in a Mopar, but a turbo'd version in some 4-door sled sounds like fun.
For a Mopar I'd build a 5.7 or 6.1 Hemi - they aren't as expensive as stated in this thread, $6000 for a running core? Try $2000~ for a 6.1, half that for a 5.7L and they have just as much potential as an LS.
Re: Anyone put a LS in their Mopar yet? [Re: SRT6776] #1328341
11/01/12 12:38 PM
11/01/12 12:38 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Where are u finding running 6.1's for 2K? Not doubting you but if that's the case that's awesome! Everything on EBay seems to be in the 5-6K range for running pull outs
Re: Anyone put a LS in their Mopar yet? [Re: WO23Coronet] #1328342
11/01/12 12:48 PM
11/01/12 12:48 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I don't know about the new hemis, but a good running 80k mile 6.0 LQ9 (345 hp) LS motor from the junkyard is $1500 here. I put one in a buddy's truck a few weeks ago.
A 5.3 in the same condition is $750.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Anyone put a LS in their Mopar yet? [Re: an8sec70cuda] #1328343
11/01/12 01:58 PM
11/01/12 01:58 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
This thread needs more Gen 3 hemi's.
This:
with one of these shiny things...
Should make a 3400 lb car with a 4 speed and a Dana go into orbit...and then I can turn up the boost.
9lbs on a similar build to mine took a 4300 lb wagon to 1.53 60 foot and 11.0 @ 124...
And I really won't have much at all into it. There are a ton of guys switching up parts over on LXForums for cheap and the fact that there are millions of cars in junk yards makes piecing this stuff together easy.
LsWHAT?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Anyone put a LS in their Mopar yet? [Re: AlexP] #1328344
11/01/12 02:19 PM
11/01/12 02:19 PM
Canada
CrAzYMoPaRGuY Offline
Canada
There is a black Magnum at well over 4000 pounds (4400?) That is running in the 9s with a genIII Hemi.
i would say this is moving.....?
9 second Magnum run
Groceries anyone???
9.69 second daily driver
Four doors, creature comforts....
9.27 second Charger
For the off road guys
9.65 second rugged yet plush Jeep
CrAzYMoPaRGuY
Re: Anyone put a LS in their Mopar yet? [Re: CrAzYMoPaRGuY] #1328345
11/01/12 05:17 PM
11/01/12 05:17 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
9 second Magnum run
Groceries anyone???
9.27 second Charger
That's Chris. The car is currently getting a 449" Aluminum motor, a bigger blower and he is going for 8's. Also, the car is currently in the UK and is going to compete in the moscow 1000.
Weight reduction isnt in the horuzon lol
