Page 13 of 16 1 2 11 12 13 14 15 16
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327858
09/16/13 03:11 PM
09/16/13 03:11 PM
California
mickm Offline
mickm  Offline
California
got her all back together, and fired her up. i had a real bad miss in the rear cylinders, but couldn't nail it down to one hole by unplugging spark plug wires, so i figured it was fuel related. ran fine under load, but part throttle and idle sucked......
tore the rear carb apart, cleaned it all out, put it back together, and it ran great!
stay tuned for the next un fun filled chapter. pics downloading as i write.....
i like the BFH in the picture there, knock some sense into that carburetor!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327859
09/16/13 09:35 PM
09/16/13 09:35 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Wow this hemi has really put you through the ringer. I hope she's all sorted out now and you get some good cruising fun before winter. My rear main has a drip too not ready to tackle it yet unless it gets worse. The only thing I've done since the install was check timing, new plugs and lash the valves after running it a few hundred miles. Good luck with the Cuda I hope your good to go now.
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: HEMIDOG 70] #1327860
09/17/13 11:03 PM
09/17/13 11:03 PM
KillerCuda Offline OP
man. i don't even know what to say at this point. shifting into second on my test drive after carb tuning, boom, lost a bunch of power. limped it home a few blocks, to find that the number one intake valve is not moving. rockers were, valve wasn't. it pulled the keepers right through it, having broke the tip of the valve off. piston smacked it, and up it went and stuck, bending the exhaust valve too. never seen anything like it to be honest.........
here we go again!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327861
09/17/13 11:04 PM
09/17/13 11:04 PM
here is the part that broke off. (peen marks in center of valve stem are from me removing it from the head....)
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327862
09/17/13 11:05 PM
09/17/13 11:05 PM
more damage. you can see where it was contacting the piston, like it stretched out before letting go.....
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327863
09/17/13 11:07 PM
09/17/13 11:07 PM
the exhaust valve keepers don't look right either, not sure if this is from what happened with the intake hitting it, or if it is on the way out too....
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327864
09/17/13 11:10 PM
09/17/13 11:10 PM
everyone else looks happy, just those two. i wonder if my lifter collapsing effected these two valves somehow? throw your best guesses at it, i am!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327865
09/17/13 11:11 PM
09/17/13 11:11 PM
my work bench is full again...... (just got it cleaned off!)
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327866
09/17/13 11:14 PM
09/17/13 11:14 PM
keepers were still in place. found the lash cap in the bottom of the head.....
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327867
09/17/13 11:17 PM
09/17/13 11:17 PM
chamber looks undamaged, taking it to my local machinist to be checked out though, cracks, valve guides, reassembly, etc.....
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327868
09/17/13 11:18 PM
09/17/13 11:18 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Sorry to hear this. Man this thing is being nasty. Who's valves are you running? Barton used Manley valves in my heads. I can't remember who's locks and retainers I'd have to find the slip. I'm getting nervous reading about all the Hemi issues. Hang in there it has to get better.
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327869
09/17/13 11:19 PM
09/17/13 11:19 PM
not really what i planned on thinking about on my vacation i am leaving for in 48 hours...
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327870
09/18/13 01:49 PM
09/18/13 01:49 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
I would recommend you get the spark plug tube oil inserts installed on your heads. These help from oil draining into your cylinders whenever you change spark plugs.
Mancini p/n: MIL27500
http://chucker54.stores.yahoo.net/mihehetuseki.html
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: Topcat] #1327871
09/18/13 03:29 PM
09/18/13 03:29 PM
California
mickm Offline
mickm  Offline
California
wow, so sorry to hear that! try and get done what you can, get it out of your mind, and enjoy your vacation!
see you when you get back!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: mickm] #1327872
09/20/13 01:45 AM
09/20/13 01:45 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
OMG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I feel your pain and I wish I could help. You have come so far with this project and it has been kicking in the teeth the whole time. Hang in there!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: Troy] #1327873
09/28/13 04:06 PM
09/28/13 04:06 PM
NJ
rdrnr6970 Offline
Your #1 source for current events
rdrnr6970  Offline
NJ
sorry to read this!thats a awesome motor.im sure yull have it running again! a valve dropped in my 5.7l hemi truck,but off course it was under warranty so they fixed it.
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: rdrnr6970] #1327874
10/07/13 09:17 PM
10/07/13 09:17 PM
one ever so slightly bent intake valve guide. called stage v, and they sent out a replacement asap......
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327875
10/07/13 09:18 PM
10/07/13 09:18 PM
the rest of the head checks out ok! very glad about that...
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: KillerCuda] #1327876
10/08/13 03:06 PM
10/08/13 03:06 PM
California
mickm Offline
mickm  Offline
California
Re: 1970 Hemi 'Cuda AAR Convertible Project........ [Re: mickm] #1327877
10/10/13 04:17 PM
10/10/13 04:17 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Buddy, you have really been through the mill with that engine. Hopefully it was the issue with the hydraulic lifter that caused your valve damage and you are on the downhill side now. That car/motor OWES you a few thousand miles of no hassles/issues driving!
