2001 3.5L Shutting off
#132782
10/06/08 08:11 AM
10/06/08 08:11 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
My wife has a 2001 Intrepid and recently the car has a habit of just shutting off for no apparent reason. It won't start immediately but given 5 mins or so starts right up and she goes on her way. No codes. The first time it did it, I was driving. I depressed the shrader vavle on the fuel rail and there was pressure.
Heres the kicker that might complicate things. Its a 2.7L car with a 2000 3.5 out of a 300M but it is all running off the 2.7 computer and people have had great success with it.
Anybody have any ideas where I can look??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 2001 3.5L Shutting off
[Re: Scottmon]
#132784
10/07/08 08:52 AM
10/07/08 08:52 AM
CJK440
Ansonia, CT
Did the same thing this AM.
There are 2 cam sensors and a crank sensor right?? Hopefully they are easily accessable.
The weird thing is it happened 3 times in a row, 3 miles from home in the AM, resets after a few seconds and is fine till the next day.
I'll fool with it tonight. If it was wiring I'd suspect it to be not as predictable. I wonder if a sensor gets a dead spot when it gets heated....
Crank sensors are $20. Cam sensors are $38.
[Re: Clair_Davis]
#132786
10/07/08 10:12 AM
10/07/08 10:12 AM
CJK440
Ansonia, CT
I have a code scanner that I will try tonight and teach my wife how to use when the car actually wont start.
I hate to throw parts at a problem but I have seen a couple things on the net pointing to cam sensor failures. I might just R&R that for the $38 and cross my fingers.
[Re: Blown71X]
#132788
10/07/08 08:16 PM
10/07/08 08:16 PM
CJK440
Ansonia, CT
I already bought a cam sensor. Before I swapped it I checked codes. None. Then I fired it up and unplugged the cam sensor. The engine immediately died like it was shut off. I turned ign off, plugged it back in and tested codes. None again. So I put a new cam sensor in and will see what happens. The wife knows how to scan codes so if it does it again, hopefully it will throw a code in no-start condition. We'll see.
[Re: CJK440]
#132789
10/08/08 08:31 AM
10/08/08 08:31 AM
CJK440
Ansonia, CT
So far so good. After 3 identical failures in a row on the morning commute, today had no issues.
[Re: CJK440]
#132790
10/08/08 09:53 AM
10/08/08 09:53 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Good to hear Any other issues with this swap? Been thinking about trying it if the right car comes along...
Common sense is a flower that does not grow in everybody's garden
[Re: Ron_M]
#132791
10/08/08 10:13 AM
10/08/08 10:13 AM
CJK440
Ansonia, CT
The swap was suprisingly straight forward. The exhaust hookup was a tad bit challenging but still not a big deal.
It helped that I obtained a wrecked 300m so I had all the little items but I am pleased with it.
[Re: CJK440]
#132792
10/08/08 12:05 PM
10/08/08 12:05 PM
Posts: 1,072 Louisville, KY.
Scottmon
Louisville, KY.
I've been thinking along the same lines...buy a 2002-2004 Intrepid with a blown 2.7 and do the swap for a nice, cheap driver.
2.7 to 3.5 swap
