Friend of mine recently moved to Wentzville near St. Louis. He needs to find a good transmission repair shop. He has a 70 Challenger with a newly rebuit 340 and 727 trans ( 2500 miles on each since the being rebuilt ). The trans will not shift out of first, has a lot of noise in gear, and slippage in 1st. The fluid level is good, and the kickdown linkage is adjusted correctly. Needs someone who kmows Mopar transmissions and does good work. Thanks. Larry
