denso alternator overcharging #1326729
10/27/12 07:19 AM
10/27/12 07:19 AM
Iowa
GreenBird Offline OP
Iowa
I did the denso alternator conversion. Also have done the ammeter bypass. All new wiring. Only problem is that once and a while, my voltmeter will show momentary spikes, like the alternator is overcharging for a moment, then not overcharging. Sounds like a ground issue somewhere. Ordinarily, I would think it was a voltage regulator ground problem, but the denso has an internal regulator. 69 Road Runner. Any ideas?
Re: denso alternator overcharging [Re: GreenBird] #1326730
10/27/12 12:48 PM
10/27/12 12:48 PM
Andrewh Offline
Andrewh  Offline
regulators change due to ground or sensing voltage.
not sure how the internal regulated work, but that is the only other thing to check, other than a bad alt.
Re: denso alternator overcharging [Re: Andrewh] #1326731
10/27/12 12:51 PM
10/27/12 12:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How many volts does it spike to?
Re: denso alternator overcharging [Re: GreenBird] #1326732
10/27/12 01:19 PM
10/27/12 01:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I had my 120 denso overcharging time to time ended up being the contact on the keyed power plug at the regulator. put a new end on the keyed power and that fixed it. so contact through the bulkhead could also give it a low voltage signal and want it to charge more!
Re: denso alternator overcharging [Re: stumpy] #1326733
10/27/12 07:59 PM
10/27/12 07:59 PM
Iowa
Iowa
Looks like about 16 on the gauge. It is very momentary -- the gauge needle will flick back and forth.
My bulkheard connectors and wires should be good as they all are new.
I ordinarily would think this was a voltage regulator ground issue. Does anyone think I should run an extra ground wire from the alternator case to ground? Any issues with doing that?
Re: denso alternator overcharging [Re: Dodgem] #1326734
10/27/12 08:02 PM
10/27/12 08:02 PM
Iowa
Iowa
I will recheck all my connections at the alternator. Thanks.
