Trans dipstick & tube ? #1326637
10/26/12 09:11 PM
10/26/12 09:11 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Can anyone post a pic of a '64 B-body trans dipstick tube? Maybe '62-'65, or later years, are the same, I don't know.
My '64 Savoy - transplanting an RB/727 - needs the tube & dipstick, and the one I have is WAY wrong: it passes right across the #8 header tube.
Thanks in advance!
Re: Trans dipstick & tube ? [Re: topside] #1326638
10/27/12 01:43 PM
10/27/12 01:43 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
bump
Re: Trans dipstick & tube ? [Re: topside] #1326639
10/27/12 02:28 PM
10/27/12 02:28 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I cut the mount off from mine. I welded a tab 90 degrees to the original tab that mounts thru the ear on the bell housing. You can rotate the tube where you need it before fabricating the tab. Way easier to install as well. Mine fits even though the motor is slid back.
Doug
Re: Trans dipstick & tube ? [Re: dvw] #1326640
10/27/12 03:01 PM
10/27/12 03:01 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
The one I have might be for a B-van, as it has a fairly low angle. Needs to be more vertical. Tried my tubing bender and that was futile.
Re: Trans dipstick & tube ? [Re: topside] #1326641
10/27/12 05:20 PM
10/27/12 05:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The early B tube places the dipstick behind the right head...there's enough room because the early motor sits further forward.
Re: Trans dipstick & tube ? [Re: John_Kunkel] #1326642
10/27/12 05:27 PM
10/27/12 05:27 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks, John, for the info & photo; that gives me something to go by.
Now all I gotta do is find a tube & stick!
Re: Trans dipstick & tube ? [Re: John_Kunkel] #1326643
10/27/12 05:40 PM
10/27/12 05:40 PM
A 1966 to 1971 Hemi tube and dipstick MIGHT work, not really sure
