Milling Edelbrock heads
#1325349
10/24/12 07:17 AM
10/24/12 07:17 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
How much has to be milled from the block face of Edelbrock's big block 84cc (or MP452) heads in order to reduce combustion chamber size by 10cc?
This is the land of the free
because of the brave
Re: Milling Edelbrock heads
[Re: Cab_Burge]
#1325352
10/24/12 01:58 PM
10/24/12 01:58 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
every .010 removed is around 2cc. So .050 would do it.
Don't forget about the intake surface Call Edelbrock on how much needs to be taken off the intake surface for every .010 taken off of the head surfaces
.0123”?
[Re: 64Post]
#1325353
10/24/12 04:56 PM
10/24/12 04:56 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: rbstroker]
#1325359
10/26/12 02:09 PM
10/26/12 02:09 PM
383man
Balt. Md
383man. Do you recall the combustion chamber size before and after shaving .040 from the RPM heads? I just got off the phone with edelbrock tech, and they couldn't give me any numbers. Cut, measure, cut and measure until getting the desired results is going to be pricey. I'd like to be able to tell the machine shop how much to cut.
I wish I did but it was a few years (at least 5) ago and I honestly dont remember. I mean of course they were the 84cc heads but I dont remember what cc's we figured for the 10.6 comp as I dont even remember the exact piston height on his 400. Very sorry. Ron
[Re: 64Post]
#1325363
11/03/12 09:06 PM
11/03/12 09:06 PM
rbstroker
West Tennessee
After referring back to my written plan, I realize that my goal is to be able to use pump gas. I installed the heads as cast for a static compression ratio of 8.87:1 That should do it. Cam selection comes after some testing of the current combination.
[Re: Vert]
#1325365
11/08/12 03:08 PM
11/08/12 03:08 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
Dodn't you need higher compression for equal power with aluminum heads? They run so much cooler I thought cylinder pressure dropped off as a result.
I had heard similar to this also many times. That you can run 1 point higher in CR relative to cast iron due to the cooling of aluminum and still avoid detonation. So, when I was building my engine I did quite a bit of research regarding this. I couldn't find any real conclusive proof that this is true, though many believe it. There are so many other factors involved, it's difficult to prove apparently. I think Car Craft actually did a relatively scientific experment trying to prove it and they couldn't.
