static compression ratio #1324628
10/22/12 08:42 PM
10/22/12 08:42 PM
West Tennessee
rbstroker Offline OP
West Tennessee
Re-doing my big block stroker motor. Strictly street. I know that camshaft selection makes a big difference, but as a rule of thumb, what static compression ratio should I be shooting for to use 89 octane mid-grade fuel with aluminum closed chamber heads? 4 speed 3.23 car. I guess that another way to ask the question is how much cranking compression is max on 89 octain pump gas with aluminum heads?
This is the land of the free because of the brave
Re: static compression ratio [Re: rbstroker] #1324629
10/22/12 09:55 PM
10/22/12 09:55 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Around 10-1, it depends on what kind of combustion chamber design is, if it requires quench, you maybe able to go higher. I went 9.5-1 with my hemi. Never have a problem with any gas. Tim
Re: static compression ratio [Re: rbstroker] #1324630
10/22/12 10:03 PM
10/22/12 10:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I went with 10.9 on a alum head SB 416.. I had it on
the dyno and had no problems with 93 octane at 38*
EDIT
on the street I plan on using 89 octane but we ran it
with 93 on the dyno for max power... I will pull 2*
of timing just to be safe
Re: static compression ratio [Re: MR_P_BODY] #1324631
10/22/12 10:49 PM
10/22/12 10:49 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
You run one more point cr with aluminium heads than iron heads, so 11:1 is non problem...the more quench you have, the less problems you will get
Dan
