Re: what size tire on a 15x3.5 weld wheel??
[Re: mopar65]
#1324346
10/22/12 12:52 PM
10/22/12 12:52 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I used to run 165/80/15 on my 3.5 centerlines with no issues up to 122mph. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Thumperdart]
#1324348
10/22/12 01:49 PM
10/22/12 01:49 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Same here................
X3, I'm going to go with a 26X6 MT radial though. I need the extra roll out to help with red lights.
[Re: Voluster]
#1324352
10/22/12 08:36 PM
10/22/12 08:36 PM
deaks
robin hood country
Bobby, my M/T front runners are radials. Mick
[Re: deaks]
#1324353
10/22/12 10:29 PM
10/22/12 10:29 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I ran the Hoosier 26" front runners on my Dart, because they had the narrowest sidewall to keep the tire off the fender, and I bought wheels that had a better offset. I believe the Wilwood brakes were the problem, they put the wheel very close to the fender lip.
[Re: ProSport]
#1324354
10/22/12 11:17 PM
10/22/12 11:17 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
thanks for the info guys. i looked and i was wrong on the name of the tire that is on my dart right now. it is the M/T sportsman pro in a 26x7.5x15 which summit says is for cars 3000 pounds and below. looks like i need these instead. Quote:
http://www.summitracing.com/parts/MTT-1573/
but when i drove sportsman pro on the street with the small block i thought the car drove like crap. the tires would fallow every little cut etc in the road. i can just see how they will handle with the big block in the car. now on the track they drove great. i mean you can drive the car with one hand at 125 mph in the 1/4 if you want.I really want to thank every one for all there great input. i am just going to get the 165 tires for the dart because i plan on driving it on the street next year and will get the M/T for the 73 duster i am going to build.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#1324356
10/23/12 09:17 AM
10/23/12 09:17 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
The 3000# rating on the sportsman pro tires is BS. I've run the 28" tall sportsman pros on my extremely nose heavy 9 sec 3800# cuda for years and never had any issues. The 28" tall version is not available in the 8 ply for heavy cars...only the 26" is. They do drive like crap on the highway though. The car had a much better feel when I ran the 165R15 tires up front, but they're too short for my taste.
[Re: an8sec70cuda]
#1324357
10/23/12 02:50 PM
10/23/12 02:50 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I ran the Mts on the 65.They were total crap.Even at the strip it felt bad.Went to the 165 80s and night and day difference.Even at 120 at the track I can let go of the wheel and its straight.I run them on the street all the time with no problems.I run MT rears that are bias.Car still handles great with radials on the front.Rocky
Chrysler Firepower
[Re: Voluster]
#1324358
10/23/12 03:08 PM
10/23/12 03:08 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Spend the extra 15 bucks a tire on some M/T sportsman tires for the front
I wouldn't run those VW tires if someone gave them to me
I've seen a couple of them blow at the top end
I run a raidal in the rear and the sportsmans in the front No problem
I don't think that there are any cheap tires, especially imported ones, since Pres. B.H.O. put the import taxes on them When it comes to tires on any of my vechicles I look at the speed rating and the weight carrying ratings before buying The 165SR15 have a weight rating of 1350 lbs each usually and a lot of the bias ply two ply front tires aren't rated for that much weight I have four sets of drag race front tires, one set of Phoenix, two sets of MT ET Fronts, which are four plys , and one set of Moroso front runners. I thought that the M/T ET fronts where two plys also, there not My new racecar will have the 8 ply funny car front tires on it, there rated for speed faster than that car should run Safety first ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Cab_Burge]
#1324359
10/23/12 05:35 PM
10/23/12 05:35 PM
deaks
robin hood country
Tread pattern looks slightly different, they are 28x7.50x15. I dont run the car on the road now, so cant comment there but they are fine at the track. Mick
[Re: mopar65]
#1324360
10/27/12 04:31 PM
10/27/12 04:31 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
A 215/75D/15 tire works great.Same size as a 7.10x15 Moroso
