Re: Best way to Turbo a 540 CI
[Re: Mpetros]
#1324193
10/21/12 11:15 PM
10/21/12 11:15 PM
Posts: 762 Southington Ct.
turbobitt
Southington Ct.
Talk with Reed at Work Turbochargers. He really knows is stuff and works in the power range your looking for in a single. http://www.workturbochargers.com/index.phpAllan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#1324194
10/22/12 01:18 AM
10/22/12 01:18 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Do you have a size limitation on the turbo? A Precision PT 106 or 114 with get you there and then some..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: Mpetros]
#1324198
10/22/12 09:50 PM
10/22/12 09:50 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Twin 88's, ala Larry Larson.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
