833 Transmission help - selector levers #1324062
10/21/12 08:05 PM
10/21/12 08:05 PM
Lawton, MI
Headhunter22 Offline OP
Lawton, MI
Hope someone can give me a hand here. I have a pro shifted hemi box I'm going through. The question I have is if anyone is familiar with selector levers with no o-ring groove cut in them? The information I have is that these were a special HD lever that require a modified cover that houses a seal. If anyone knows of another method I would appreciate it. Not afraid to spend the money at Liberty to have a cover modified but if anyone else knows anything I would appreciate any help.
Steve
Re: 833 Transmission help - selector levers [Re: Headhunter22] #1324063
10/21/12 09:08 PM
10/21/12 09:08 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Steve
Those are the HD modified levers by Liberty's
They can machine you side cover to accept a lip seal to keep the lube in the box where it belongs.I have had a few early Liberty boxes apart and they didn't use seals in the older race boxes I believe.I had my bro-in-law machine a few covers for me after I cracked one with those shafts in it.If I still have a spare I will work you a deal
Gus
64 Plymouth Savoy
Dana 60
Re: 833 Transmission help - selector levers [Re: fourgearsavoy] #1324064
10/21/12 09:17 PM
10/21/12 09:17 PM
Lawton, MI
Lawton, MI
Sounds good, if you find one and want to sell, let me know. I know this is an old liberty box, dates on sliders / cluster is '76 with liberty stampings. It's an a-body box as well, would be interesting to have the history..
Re: 833 Transmission help - selector levers [Re: Headhunter22] #1324065
10/24/12 10:35 PM
10/24/12 10:35 PM
Rittman Ohio
Rittman Ohio
Steve you have a PM
Gus
64 Plymouth Savoy
Dana 60
Re: 833 Transmission help - selector levers [Re: fourgearsavoy] #1324066
11/03/12 11:01 AM
11/03/12 11:01 AM
Lawton, MI
Lawton, MI
For reference, I've posted a picture of the liberty cover vs. a stock cover. Thanks again Gus. The HD cover has the c'bores for seals vs. o-ring grooves on the levers.
Steve
