DA getting better, ET and MPH are not! #1322694
10/19/12 01:39 AM
10/19/12 01:39 AM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
Here is the car 70 Duster 3510 with me in it. 360 pocket ported J heads 2.02 valve, Hughes 232/237 hydraulic cam, 9.9 compression, LD340 (divider cut down) Annular 750, (same issue with my vac. 750) 1" 4 hole spacer heddman 1 5/8" headers, 3" exh. to the bumper with ultraflows. Trans is a 727 with a 9.5 Dynamic converter that stalls about 3500. Rear is an 8-3/4 with 3.91 gears and 27" tall tire. The fuel system consist of a stock tank a 3/8" pickup (I made it myself, copied the original but made it go a little deeper in the tank) -6 braided line attaches the pickup to 3/8" aluminum line and from the aluminum line to the fuel pump is -6 braided line. the fuel pump is a holley 120 gph mechanical. From the pump to the carb is 3/8" steel line with a clear plastic 3/8" filter before the carb. I know it's not the best filter to use but I was having a problem in the summer with fuel boiling off. Nothing is near heat. I installed a return line using the factory fuel line and I put an .039 orifice in to restrict the fuel going back to the tank and it worked great for hot weather driving keeping the fuel filter full all the time. In the not so good air 2,100'DA 85-90 degree it was going mid-high 107 mph and low-mid 12.40's In good air last night 200'DA 45-50 degree air it went mid 108 mph and 12.37. I pulled a couple plugs today and they were white with black specs. I have bumped the jet size from the factory jet sizes Sorry I don't recall whats in there right now, but I went up 3 numbers in the front and 5 in the back with no change. I really think the it should have gone in the 12.20's or even the teens and close to 110 last night. I need some suggestions. I am going to try and put a fuel pressure gauge on the car to see whats going on with that. Sorry this is so long.
Re: DA getting better, ET and MPH are not! [Re: JCCuda] #1322695
10/19/12 02:29 AM
10/19/12 02:29 AM
Check the size of the needles and seats,if there not at least .110 change them to .120 The current pump(ethahno 10 or 15%) swill needs more volume than the gas of old The car is talking to you, you jetted it up and it did not respond accordingly, answer is not enough fuel getting to the jets Time to find out why, look for the obviuos stuff first
Re: DA getting better, ET and MPH are not! [Re: Cab_Burge] #1322696
10/19/12 02:42 AM
10/19/12 02:42 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Did you go up 8 sizes all at once or incremental steps. may have gone over the other way.
Re: DA getting better, ET and MPH are not! [Re: JCCuda] #1322697
10/19/12 09:02 AM
10/19/12 09:02 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Black specs is too much timing or not enough octane.
Re: DA getting better, ET and MPH are not! [Re: Dodgem] #1322698
10/19/12 11:30 AM
10/19/12 11:30 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
True OR too hot of a plug. I did nothing but go from an ngk # 7 to an 8 and most of the peppering is gone so now I`ll fatten up the top end and we should be good to go. Not too sure about the mechanical pump though.............
Re: DA getting better, ET and MPH are not! [Re: Cab_Burge] #1322699
10/19/12 04:26 PM
10/19/12 04:26 PM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
That's a good idea Cab. I didn't even think of that.
If the .120's are good would .130's be better?
RobX4406 No I went up 2 in the front and back first with no improvement so I added some more and still no change.
Dodgem too lean will cause that also. My total is at 34 degrees and I run 93 octane and mix some 110 with it.
Thumperdart I have autolite 3924's in the car now but I have a set of 3923's to put in it.
Re: DA getting better, ET and MPH are not! [Re: JCCuda] #1322700
10/19/12 05:13 PM
10/19/12 05:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
120 needle and seats will be plenty... since you jetted
up and no change I would do 2 things... try the N/S
and do a flow test on the pump... you will have to
use a can hanging above to run the engine and measure
the time to flow a gal from the pump right where it
goes into the carb
Re: DA getting better, ET and MPH are not! [Re: MR_P_BODY] #1322701
10/19/12 07:04 PM
10/19/12 07:04 PM
RobX4406 Offline
RobX4406  Offline
If you jet up and there is no change, likely fuel delivery issues as mentioned.
Try raising the float level a little and see if it improves. It might run like junk at idle.
Re: DA getting better, ET and MPH are not! [Re: JCCuda] #1322702
10/19/12 08:06 PM
10/19/12 08:06 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
If you have 5 psi at WOT at the top of any gear, you are fine. It is hard to believe that those carbs don't have enought needle orifice to support 400 hp, but it wont hurt to put larger ones in.
Did you put the return line in before or after you went 107+ in the summer? You could simply plug or by pass that at the track to see if it makes a difference.
It is a street car right? What all has happened with the car since the summer track passes? How many miles have you put on it? You're looking for about 10 to 15 "missing" hp. Really not that much. The state of tune and the car/engine details could simply be a little different. Things like fresh plugs, tire pressure, shift point, oil, oil temp and engine cool down can add up to make this kind of a difference in my street cars between having the car really ready, verses showing up to make some passes.
Re: DA getting better, ET and MPH are not! [Re: BSB67] #1322703
10/20/12 10:40 AM
10/20/12 10:40 AM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
I put the return line in after I started racing the car this year and it didn't seem to make any difference in the ET or MPH. It did keep the car from stalling and not starting right away when driving it in the hot weather. I might plug the return just to double check though.
Yes it is a street car but I have raced it almost every Wed. night in a $500.00 eliminator since, so tire press. oil, oil temp., plugs are not a factor and I go into my burnout at 145-150 every pass. I replaced my clutch fan with a water pump drive in the middle of August. (saw no change in mph or et from that either?)so I'm not just showing up to make some passes. These are some good thoughts. You made me go back and double check my memory on these items. Thank You.
Re: UPDATE DA getting better, ET and MPH are not! [Re: JCCuda] #1322704
07/12/13 11:38 AM
07/12/13 11:38 AM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
Finally got back to the track Wednesday night. I put in the .120 needle and seats and added a Holley electric fuel pressure gauge, changed the rear float bowl for one with a notched float and jet extensions also raised the rear float level. At idle the fuel press. is 5 psi. Driving through the pits it's 7 psi and on the track it's 3-4 psi so I suspect this is probably the issue. A friend used to work for IROC and he has one of the mechanical Holley pumps they used to run on the Daytona's and Avengers so he's going to give that to me to try. DA was about 2,900' and the temp. was 88 and humid. Best pass was 12.517 @ 106.87 which is right inline with last years numbers. Still no color on the plugs. I will also try plugging the return line for racing.
Re: UPDATE DA getting better, ET and MPH are not! [Re: JCCuda] #1322705
07/12/13 02:18 PM
07/12/13 02:18 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
I had same type of trouble with my dart and also pretty close combo, It picked up with a holley electric pump and regulator about .4 in the 1/4. No return line though. I was using a high volume mechanical pump before that.
Re: UPDATE DA getting better, ET and MPH are not! [Re: gtsdude] #1322706
07/12/13 02:24 PM
07/12/13 02:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly, unless you have to why run a mechanical pump?
Re: UPDATE DA getting better, ET and MPH are not! [Re: JCCuda] #1322707
07/12/13 05:56 PM
07/12/13 05:56 PM
Q
Quicktree Offline
Quicktree  Offline
Q
color on the plug tells you nothing..
Re: UPDATE DA getting better, ET and MPH are not! [Re: Quicktree] #1322708
07/12/13 10:43 PM
07/12/13 10:43 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Exactly. In the old days we'd tune by plug color by making a run on FRESH plugs, shutting off at the finish line and coasting to the return road. We'd look at plus right then. Putting back to the trailer would color the plugs and not tell us anything.
Since then, with these high powered ignitions, color on the plus is almost meaningless. if it's THAT lean, it won't run. If it's THAT rich you wouldn't be able do drive it.
The best way to see your mixture is with EGT readings. Period. BUT...remember that a mechanical pump is subject to ALOT more heat soak than an electric pump...THUS you having issues during hot weather driving.
An electric pump, even a "street/strip" Carter or like should show you a gain. Just remember to wire it THROUGH the ignition switch so it shuts off with the key.
