E-Body hood Hindge ID #1321981
10/17/12 08:36 PM
10/17/12 08:36 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Please post up pics of the different e-body hood hindges by year and note differences.
Thank You,
MLR426
Re: E-Body hood Hindge ID [Re: MLR426] #1321982
10/17/12 08:38 PM
10/17/12 08:38 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
This is a start
hinges
Re: E-Body hood Hindge ID [Re: YYZ] #1321983
10/17/12 09:27 PM
10/17/12 09:27 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
This is a start
hinges
Thanks I knew this was talked about.
MLR426
Re: E-Body hood Hindge ID [Re: MLR426] #1321984
10/17/12 09:29 PM
10/17/12 09:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a couple sets Martin, 70 and 71
Re: E-Body hood Hindge ID [Re: MLR426] #1321985
10/17/12 09:31 PM
10/17/12 09:31 PM
New State
kidmopar Offline
kidmopar  Offline
New State
Thank You,
MLR426
Re: E-Body hood Hindge ID [Re: ScottSmith_Harms] #1321986
10/17/12 11:44 PM
10/17/12 11:44 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
I may be sending someone your way. I have a friend doing a 71 cuda, and he needs hindges and I told him 71-72' were the same but he wanted to see pics of the different ones. I don't have an extra set to give him, yes I said give, he's a good friend. My early built 71 had 70 style. I don't think he cares which ones he gets.
MLR426
Re: E-Body hood Hindge ID [Re: MLR426] #1321987
10/19/12 01:19 AM
10/19/12 01:19 AM
North America
2002bluert Offline
2002bluert  Offline
North America
Can you use one 71 hinge with the teeth on one side and a 72 to 74 without the teeth on the other side? And are the AMD hinges any good?
Re: E-Body hood Hindge ID [Re: 2002bluert] #1321988
10/19/12 09:32 AM
10/19/12 09:32 AM
WI
RestoRick Offline
RestoRick  Offline
WI
You could conceivably use tooth & non-tooth types on the same car and in fact I've seen one example of this on a production vehicle that appeared to be original.
I personally wouldn't recommend doing it however... while the rivet positions where the folding occurs are the same, I'd be concerned about differences in resistance possibly making the hood want to twist as it's lowered. When I rebuild hood hinges I match the assembly frictions
side-to-side for this reason.
Looks like I should put together a pictorial series showing the year variations... in all my spare time.
Rick
