Much (any?) advantage to a higher rocker ratio here?
#1321805
10/17/12 01:06 PM
10/17/12 01:06 PM
BradH
The 452 is going back together w/ ported Victor heads that flow the following:
Lift -- Int / Exh (no tube) .100 --- 73 / 54 .200 -- 155 / 105 .300 -- 224 / 162 .400 -- 282 / 200 .500 -- 317 / 219 .550 -- 329 / 229 .600 -- 343 / 236 .650 -- 346 / 244 .700 -- 350 / 247
The CR should be 10.8 - 10.9, the converter flash is ~ 4500, peak RPM probably 7000-7200. The cam's a solid roller 265 @ .050", .650" gross (1.5), 108 LSA.
If I bumped up the rocker ratio to 1.6 (either on intake only or both int & exh), it's more like .690" gross. Does this look like a combination that might show benefits w/ the higher ratio, or given the street-driven nature of the car, would the lower ratio help to reduce wear & tear on the valve train?
FWIW #1 - The cam lobes are compatible with the higher ratio and the springs can support the additional lift.
FWIW #2 - I already have complete sets of rockers in both 1.5 and 1.6 ratios, so there's no cost implication (at least in the short term) associated with the ratio decision.
Re: Much (any?) advantage to a higher rocker ratio here?
[Re: Jeremiah]
#1321807
10/17/12 01:17 PM
10/17/12 01:17 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Higher ratio rocker lets you run a larger base circle cam and still get the lift you want.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1321809
10/17/12 03:53 PM
10/17/12 03:53 PM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
Next dumb question: What does a larger base circle do for me? Faster ramp on the cam?
[Re: BradH]
#1321810
10/17/12 03:56 PM
10/17/12 03:56 PM
Jeremiah
Rogue River, OR
What is the lash on that cam Brad?
I've seen the same lobe family spec'd anywhere from .018" - .028". I figured I'd start at .024" and go up or down from there depending on how the new combination responds.
And now for dumb question number 3:
When you spec a cam do you account for lash when deciding on max lift? In example say I have heads that flow 372 at .700 and the cam manufacturer specs .024 lash. Do I want to run a .724ish lift cam?
If I am thread jacking too far off topic feel free to give me the boot.
[Re: BradH]
#1321811
10/17/12 04:07 PM
10/17/12 04:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Faster open rate... plus run more lift than you really need... that way it spends twice the time at that lift (front and back of the lobe).... plus I would only do the intakes... pressure is working on the exhaust side(I never seen added ratio help exhaust unless you were way off)
[Re: Jeremiah]
#1321812
10/17/12 04:07 PM
10/17/12 04:07 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
oh boy, I had the plessure of spending a hour on the phone with Dewayne a couple weeks ago and spent a half hour on this subject
because i remember everything, I sent you a PM about this subject maybe 5-7 years ago and I remember exactly what you said to me
[Re: MR_P_BODY]
#1321813
10/17/12 04:42 PM
10/17/12 04:42 PM
BradH
... I would only do the intakes... I never seen added ratio help exhaust unless you were way off
My thinking / experience, too.
[Re: sixpackgut]
#1321814
10/17/12 04:44 PM
10/17/12 04:44 PM
BradH
1. I can't remember what I said 5-7 days ago, much less 5-7 years.
2. I do remember his name is spelled "Dwayne" (only one "e").
3. So, what was the result of the conversation w/ him?
[Re: Jeremiah]
#1321815
10/17/12 04:52 PM
10/17/12 04:52 PM
BradH
You also really need to take into account loaded valve train deflection (pushrod & rocker arm flex), actual "as installed" rocker arm ratios, and the like, in addition to lash.
So, yes, you can use the gross lift minus lash as a target value, but what you'll see in the real world w/ all the parts working together can be different still.
[Re: Jeremiah]
#1321816
10/17/12 05:22 PM
10/17/12 05:22 PM
MR_P_BODY
Actually you would want about .770 lift... like I said you have max flow at .700 but your only there once if you go with .724 but if you go with more lift you will be at it twice
[Re: BradH]
#1321820
10/17/12 11:36 PM
10/17/12 11:36 PM
sixpackgut
Charleston
1. I can't remember what I said 5-7 days ago, much less 5-7 years. you said that it was a waste of time. and told me at best I may pick up 6 hp
2. I do remember his name is spelled "Dwayne" (only one "e"). it's a tricky name.
3. So, what was the result of the conversation w/ him? you made a great post about your conversation with Dwayne on rocker ratios. this was back when you bought the victors. about 50 years ago it seems. I wish I would have saved it
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1321822
10/18/12 10:18 AM
10/18/12 10:18 AM
BradH
Brad: ... Dwayne: Brad: Dwayne: Brad: Dwayne:
Yeah, that's pretty much how most of my discussions w/ Dwayne have gone over the years...
