67 RB Exhaust Manifold - Same Pipes for LP & HP?
#1321632
10/17/12 01:10 AM
10/17/12 01:10 AM
Posts: 4,292 Morrow, OH
markz528
Morrow, OH
For a 67 Coronet with a 440, do the low performance and high performance manifolds exit in the same spot? Another words, are the exhaust pipes interchangeable between the two?
Re: 67 RB Exhaust Manifold - Same Pipes for LP & HP?
[Re: Jim_Lusk]
#1321634
10/17/12 01:11 PM
10/17/12 01:11 PM
Posts: 6,024 Morningside
AdventurerSport
waaaay out there in left field
Morningside
they are different, I have the correct HP manifolds on my '67 R/T and they are very different from the ones off my '67 New Yorker...(both 440) JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: markz528]
#1321635
10/17/12 03:10 PM
10/17/12 03:10 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
As said no , and FYI the low performance version of the 440 in 1967 was not available in the Coronet line .
[Re: markz528]
#1321639
10/17/12 09:17 PM
10/17/12 09:17 PM
JohnRR
Yes studs should be the same , flanges on the head mounting surface would be the same thickness, you should be able to take the manifold out from the top .
Would have to take the AC out to take the passenger side out from the top. Do NOT want to do that. Looks like there is enough room to get the old one out the bottom but not sure of the HP version.
I am starting to figure out the differences and I believe I can overcome them but I may change the manifolds.
I assume the passenger side manifold is the same as a 68/69 -- the one that ends in 900 -- correct?
Yes the pass side is the same 67-69 , you may want to unbolt the mounts and jack one side at a time and do it from the top, getting the HP back in with a 440 is going to be real tight especially on the Pass side .
