Re: 88 ramcharger charging issue
[Re: Moparnut426]
#1321407
10/16/12 05:39 PM
10/16/12 05:39 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Just a shot in the dark, you've checked the fusible links? You SURE?
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#1321409
10/16/12 05:49 PM
10/16/12 05:49 PM
Posts: 15,487 Florida
scratchnfotraction
Robert
![](/ubbthreads/images/graemlins/iagree.gif)
x2
check the batt wire running down the VC to the firewall. if it has a factory plug connection into the wireharness,check to see how the condition of it is.
[Re: Moparnut426]
#1321412
10/16/12 06:44 PM
10/16/12 06:44 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I did have a poped fuse link, 20 guage wire, I just jumped that as a test and still nothing, Ill have to get down and dirty with it tomarrow. Might hard wire the thing from scratch and see if it works that way as a test, the go from there. Thanks guys. Oh, Im gonna eliminate the fuse links ASAP!! LOL ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Moparnut426]
#1321413
10/16/12 07:40 PM
10/16/12 07:40 PM
RapidRobert
remove the 2 (blue/green) field terminals from the alt male field terminals and with the throttle on fast idle with headlights/AC on, jump from the batt positive post to either male alt field terminal then with your VOM connected to the large "batt" alt output stud then also jump from the other alt male field terminal to ground for 3 seconds MAX, just long enough for you to take a reading on the meter & if it's 15+ volts the alt is good. Reconnect the 2 field leads. When the key is "on" (ign1 switched 12V) check if you have near batt voltage at (1) the blue wire field terminal at the alt and (2) the blue wire at the reg connector & it's the top wire with the connector triangle facing "up" like a pyramid. if not hot at both then find/fix the open. If both are hot take off the green wire connector from its' alt male field terminal (one of the 2 you prior removed then replaced) and with a jumper wire jump the green wire male terminal to ground for 3 seconds MAX like before at a fast idle/accessories on, & if it charges then (1) the reg is bad (2) the reg ain't grounded) (3) there's an open in the green wire from alt to reg & note on #3 that unless there's been excessive amperage flow or the insulation has been cut/pinched/chafed, and no excessive flexing that has broken some strands, wires go bad at the terminals/connections at the ends as normal electron flow does not age/harm copper wiring strands so look at the green field alt female connector and on the other end of it the reg plug in for an open/loose connection. Holler how it goes EDIT when doing the 3 second full fielding it's a good precaution to have all light bulbs off and with a jumper cable to connect the alt output "batt" stud to the batt positive post (or starter relay large "batt" stud)
[Re: stumpy]
#1321415
10/17/12 01:11 AM
10/17/12 01:11 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Its been a while since I worked on an 88 Ramcharger but I do believe there was no external regulator on that year. It basically works the same as the external reg but the PCM controls the charging system on all the 88 Trucks I remember. But only the 5.9 might still have an external reg since the 5.9 truck still used a carb in 88 so it may have had an external reg but I would have to look at the wire diagrahm to be sure. The 3.9 and 5.2 were both throttle body fuel inj in 88. Ron
[Re: Moparnut426]
#1321417
10/17/12 10:11 AM
10/17/12 10:11 AM
Moparnut426
Well guys, Thanks for all your help and sugestions. I used Rapidroberts test proceedures and the altornators fine, tested the VR, which is a brand new unit from MOPAR, and its bad. Cant believe it, decide to buy from ma MoPar and get bit. Well looks like Ill just get either another one or get a refund and buy a "junk" napa unit. LOL Charged good with the VR I had in my tool box that I didnt trust. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Moparnut426]
#1321420
10/17/12 11:50 AM
10/17/12 11:50 AM
RapidRobert
If it ever acts up again & goes to max charge as opposed to zero charging (bad VR's can do one or the other) I would unplug it till you make it home. Slightly deep cycle discharging the batt is WAY less damaging than full fielding the system. glad ya got it squared away.
