AJ and the championship #1321296
10/16/12 10:09 AM
10/16/12 10:09 AM
Finally a HUSKER again
Moparnut426 Offline OP
Does anyyone know what is neede to basically wrap it up? Can he go say 1 or 2 rounds and seal the deal up, or is he gonna need to go all the way to the wire?
Really hope he can pull it out, we need another mopar champ!!!
Re: AJ and the championship [Re: Moparnut426] #1321297
10/16/12 10:20 AM
10/16/12 10:20 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
2 races left and you can get 20 points per round won.
Setting new records is worth 20 points so its not wrapped up yet.
Plus the qualifying and what they call the "little points"
http://www.nhra.com/points/fullthrottle.aspx
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: AJ and the championship [Re: Moparnut426] #1321298
10/16/12 12:18 PM
10/16/12 12:18 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Come on AJ you can do it!!!!!!
Re: AJ and the championship [Re: RV2] #1321299
10/16/12 02:04 PM
10/16/12 02:04 PM
Out West
408strokerdart Offline
Out West
Does low qualifier = points?
Re: AJ and the championship [Re: 408strokerdart] #1321300
10/16/12 02:43 PM
10/16/12 02:43 PM
PA.
"Little"John
"Little"John
PA.
Yes plus every round of qualifying the number 1 gets 3 extra points, 2nd fastest gets 2 points, 3rd fastest gets 1 point. This is to keep guys from testing during qualifying. It pays to go fast every round. Bonus points are during qualifying only.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
Re: AJ and the championship [Re: pittsburghracer] #1321301
10/16/12 04:21 PM
10/16/12 04:21 PM
Out West
Out West
Didn't know that. Thanks for the info.
Re: AJ and the championship [Re: 408strokerdart] #1321302
10/16/12 05:46 PM
10/16/12 05:46 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Not close to over or locked up. The redlight really hurt last time out. Could have used all the rounds out there.
He's only 82 points ahead. Basically 5 rounds without bonus. If line goes out early in either of the last two, he' likely done.
If you sweep everything, you get 130 points for a weekend. Get a record and it's 150 points. There are points for each round of qualifying (3,2,1), and for your ladder position from 8 to 1.
NHRA NATIONAL EVENTS
Winner 100
Runner-up 80
Third-round loser 60
Second-round loser 40
First-round loser 20
Additional points are awarded at national events as follows:
10 points to all contestants - one qualifying run required.
20 points for establishing an official e.t. record.
Performance bonus points are awarded for each qualifying session as follows:
Low e.t. of each session 3
Second-quickest 2
Third-quickest 1
Performance bonus points WILL NOT be awarded for any session unable to be completed.
Qualifying positions earn points as follows:
1st 8
2nd 7
3rd 6
4th 5
5th & 6th 4
7th & 8th 3
9th thru 12th 2
13th thru 16th 1
Re: AJ and the championship [Re: RobX4406] #1321303
10/16/12 06:15 PM
10/16/12 06:15 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Dont think anyone will be able to reset the national record at Vegas or Pomona...
Tony
70 AARCuda Vitamin C
Re: AJ and the championship [Re: 70AARcuda] #1321304
10/16/12 06:16 PM
10/16/12 06:16 PM
RobX4406 Offline
RobX4406  Offline
Agreed unless there are some crazy conditions at pomona.
Re: AJ and the championship [Re: RobX4406] #1321305
10/16/12 06:57 PM
10/16/12 06:57 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Another good thing is that V.Gaines knocked off Line the next round and did not let him gain that many points on AJ.
Re: AJ and the championship [Re: b1dartsport] #1321306
10/16/12 08:12 PM
10/16/12 08:12 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I just AJ don't shoot himself in the foot.
Re: AJ and the championship [Re: 408strokerdart] #1321307
10/16/12 09:49 PM
10/16/12 09:49 PM
toledo, ohio
plasticfantastic Offline
toledo, ohio
yeah it gets interesting now, line is 82 points out, but if he makes up that 2 points in qualifying, he just went from 5 rounds out to 4. he basically made up 20 points if you think of it like that.
Lines 5 rounds out, with 8 rounds left. I think that all AJ has to do is keep it at 5 going into Pomona, so matching Line round for round in vegas will pretty much force line to need to win and set a record to seal the deal, regardless of what AJ does in Pomona.
Re: AJ and the championship [Re: plasticfantastic] #1321308
10/18/12 08:33 PM
10/18/12 08:33 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Several NHRA Pro Stock regulars also were making some runs on The Strip. Allen Johnson’s first run of the session on Wednesday was 6.686 at 206.61 mph. His first run on Thursday was 6.637/208.36, which is two-hundredths faster than the No. 1 Qualifier at the LVMS spring event. Look out next weekend! [10/18/2012]
Tony
Re: AJ and the championship [Re: 70AARcuda] #1321309
10/18/12 09:41 PM
10/18/12 09:41 PM
Guitar Jones Offline
That's great but what did the others do?
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
