Re: Mopar 727 Transmission Won't Go!!! [Re: MagicMan65] #1320469
10/17/12 04:07 PM
10/17/12 04:07 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Another possiblity is that one or both pieces of the Low/Reverse band apply link have broken. Kind of looks like this: 8=8 It happened to my 727 without warning.
Or the band is not adjusted properly/broken.
Re: Mopar 727 Transmission Won't Go!!! [Re: Dave Watt] #1320470
10/17/12 09:44 PM
10/17/12 09:44 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
On the passenger side of the trans there is an 1/8 pipe plug port.
Get a gauge with at least a minimum 200 psi and a hose.
This plug is angled towards the rear and is not at the servos.
Check pressure with it in drive.
get back to us with that number.
Re: Mopar 727 Transmission Won't Go!!! [Re: 4406bbl] #1320471
10/17/12 11:43 PM
10/17/12 11:43 PM
Canada's West Coast
Graham Offline
Graham  Offline
Canada's West Coast
The 2800 stall converter might be the cause of your problem. Remember it won't perform properly until it passes it's rated stall speed. On the jack stands there is little or no resistance for the converter to stall against. So, put it all back together and see what happens when you engage the transmission and apply the throttle with all 4 wheels on the ground. Take the converter past the 2800 stall speed and see what happens. I would also think that if the ears(lugs)were broken on the internal pump gear you'd find metal contamination in the oil and on the filter.
transman
Re: Mopar 727 Transmission Won't Go!!! [Re: John_Kunkel] #1320472
10/18/12 11:07 PM
10/18/12 11:07 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Thanks for the input guys; my question is if you think the pump has failed then why do I have good fluid flow to the trans cooler?
See my comment above, "even with the drive tangs broken there can be enough friction between the pump rotor and drive hub to create some pressure but not enough to engage a clutch."
if you want to solve the Issue, John's the man on T/F's. Nuff said
Re: Mopar 727 Transmission Won't Go!!! [Re: Graham] #1320473
10/18/12 11:19 PM
10/18/12 11:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
transman
A 2800 stall will pull perfectly fine from an idle on. It's just fully locked at 2800.
Re: Mopar 727 Transmission Won't Go!!! [Re: stumpy] #1320474
10/19/12 08:48 AM
10/19/12 08:48 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
transman
LOL! Yes pretty tight heck I have a 5000 ultamite seems tight to me.
stock are 2200 to 2400
