thought I'd share this - I installed all the pistons yesterday, made sure all the indents in the piston edges were facing forward.
Checked for bearing clearance, thats all good & then I noticed a cap on #5 looking funny as I was checking the clearance between the rods. It looked like I had a bit of a tapered gap going from one side of the cap to the other.
so I pulled the cap & started to suspect the rods are backwards...
the large chamfers on the rods & caps are facing each other. I was also told by a guy whose rebuilt a few mopars that the groove on the cap is meant to squirt oil towards the opposite cyl wall, these are pointing to the block castings.
Pulled 2 more caps, 1 & 5 & you can see the bevels are facing one another.
I finally noticed the bold type paragraph in the FSM on pg 66 that says which way the bevels face for all the pistons. Ultimately it makes me assume the machine shop pressed the rods in backwards. It does spin over w/o resistance but now it looks like I gotta take them out, have them re-press the rods back on & do it all over.
I believe the bevels are there to clearance the casting parts of the crank to the L & R of the rod journals & I assume thats pretty important. Hate to do all this work & screw it up over something so stupid.
Are the bearing tangs / tabs supposed to be on the same side of the con rod when assembled? They'd be on the same bolt then - that's correct isn't it?
My problem is I didn't disassemble this motor as I could not get the dampener pulley bolt off so I took it to the machine shop & they disassembled it. Had I done it I've have many pictures - too bad
Anyone ever run a motor with the rods facing the wrong way - whats the end result?
Thanks all,Evan
