Progressive or 1:1 on Dual Quads? #1319938
10/14/12 12:14 AM
10/14/12 12:14 AM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
I had a complete 472 Hemi built and dyno tunned by an engine builder. Starting to put the final pieces on it and notice that the have the progressive linkage set up in a 1:1 configuration. I am wondering pros and cons of both ways and if I should worry about it. I can see where 1:1 might be more dificult to tune, but it was dyno tunned already. But progressive seems like it would run the front cylenders lean at an idle?
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: Progressive or 1:1 on Dual Quads? [Re: Mopar_Mudder] #1319939
10/14/12 01:53 AM
10/14/12 01:53 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I run dual quads on most of my stuff over the last 20 years, even my work truck was 440 2x4bbl.
I don't run progressive linkage, I like running 1:1. I have fancy progressive linkage on my Charger, it's locked out to give 1:1.
I have a CH28 and two Edelbrock 500cfm carbs ready to go on my motorhome, it will be 1:1 too....
Jensen Interceptor drivability with 3.08 gears, stock convertor, and a little blip on the throttle gets a tiny chirp...
http://www.youtube.com/watch?v=NStpPLbRPL4
CrAzYMoPaRGuY
Re: Progressive or 1:1 on Dual Quads? [Re: CrAzYMoPaRGuY] #1319940
10/14/12 06:59 AM
10/14/12 06:59 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I run 1-1 on my tunnelram as well, runs fantastic.Dave
Re: Progressive or 1:1 on Dual Quads? [Re: quickd100] #1319941
10/14/12 09:00 AM
10/14/12 09:00 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I run progressive. I like it. Run it both ways and see which one you like best. Every motor is different
Re: Progressive or 1:1 on Dual Quads? [Re: bobs66440] #1319942
10/14/12 10:35 AM
10/14/12 10:35 AM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
I run 1:1 on my 526 hemi and it works great.
Re: Progressive or 1:1 on Dual Quads? [Re: Jack Zupan] #1319943
10/14/12 11:16 AM
10/14/12 11:16 AM
west palm beach, florida
modelmakerinc Offline
Can someone please expand on the terminology (1:1 & progressive) for those whose might be curious. Thanks
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Progressive or 1:1 on Dual Quads? [Re: Jack Zupan] #1319944
10/14/12 11:36 AM
10/14/12 11:36 AM
Wisconsin
Wisconsin
Thanks for all the replys. One less thing to worry about, I will leave it 1:1 and see how it runs, easy enough to change in the future.
Re: Progressive or 1:1 on Dual Quads? [Re: Mopar_Mudder] #1319945
10/14/12 01:11 PM
10/14/12 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What intake are you using , that will determine which way you can or want to run ?
Re: Progressive or 1:1 on Dual Quads? [Re: modelmakerinc] #1319946
10/14/12 02:20 PM
10/14/12 02:20 PM
bobs66440 Offline
bobs66440  Offline
1:1 means that both carbs' throttles are opened the same amount at the same time via a linkage connecting the two. Progressive means the the primary (rear) carburetor is opened first and the secondary one opens sometime after it via a progressive linkage connecting the two. They usually are set up to both hit full throttle at the same time...
Re: Progressive or 1:1 on Dual Quads? [Re: JohnRR] #1319947
10/14/12 06:56 PM
10/14/12 06:56 PM
Wisconsin
Wisconsin
It is the repop of the stock Hemi intake, orignal carb spacing dual plane.
Re: Progressive or 1:1 on Dual Quads? [Re: Mopar_Mudder] #1319948
10/14/12 11:15 PM
10/14/12 11:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can run progressive with that intake if you choose since it's a dual plane.
Re: Progressive or 1:1 on Dual Quads? [Re: JohnRR] #1319949
10/14/12 11:18 PM
10/14/12 11:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And you can save a few bucks on fuel !
Re: Progressive or 1:1 on Dual Quads? [Re: quickd100] #1319950
10/15/12 06:53 AM
10/15/12 06:53 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Question for the secondary carb running progressive....should I back the idle circuit all the way out since the engine is running with only the rear one? Should I treat the Two carbs like a double pump Holley and adjust it like 4 corner air bleed screws. Should the rear carb be more lean than the front one? Should they be equal?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Progressive or 1:1 on Dual Quads? [Re: JohnRR] #1319951
10/15/12 09:23 AM
10/15/12 09:23 AM
bobs66440 Offline
bobs66440  Offline
I didn't realize it made a difference, running dual/single plane with progressive/1:1 linkage. I switched mine (single plane Offy) from progressive to 1:1 yesterday and it is WAY better. Why does it matter?
Re: Progressive or 1:1 on Dual Quads? [Re: bobs66440] #1319952
10/15/12 10:24 AM
10/15/12 10:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would have to see your intake but since the OP has a Hemi there are a few different intakes, if he had a Stage 5 intake he would definitely have to run it 1:1 because it is basically 2 single plane intakes with a small passage that wouldn't feed the opposing 4 cylinders very well, if at all .
Re: Progressive or 1:1 on Dual Quads? [Re: JohnRR] #1319953
10/16/12 06:35 AM
10/16/12 06:35 AM
bobs66440 Offline
bobs66440  Offline
It's the same as this one.
http://www.ebay.com/itm/Offenhauser-5206-Dual-Quad-Low-Rise-Intake-Manifold-/310383386977
Re: Progressive or 1:1 on Dual Quads? [Re: JohnRR] #1319954
10/16/12 07:16 AM
10/16/12 07:16 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
I use 1:1
Re: Progressive or 1:1 on Dual Quads? [Re: bobs66440] #1319955
10/16/12 11:33 AM
10/16/12 11:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bob , on that intake 1:1 would be the better choice for performance because of carb to port layout , running off just one at first would cause the 4 cylinders at the opposite end to not see a decent fuel/air mixture.
You could switch to a smaller set of carbs if you wanted , throttle response would probably improve.
Re: Progressive or 1:1 on Dual Quads? [Re: JohnRR] #1319956
10/16/12 12:19 PM
10/16/12 12:19 PM
bobs66440 Offline
bobs66440  Offline
Ok, thanks
Re: Progressive or 1:1 on Dual Quads? [Re: Mopar_Mudder] #1319957
10/25/12 12:25 PM
10/25/12 12:25 PM
Wisconsin
Wisconsin
One more quick question. If I am running 1:1 linkage, is their any issue with running the choke only on the back carb? Should the two be linked together? Not that it will really be driven in the cold
