Re: Does a radiator cap ever go bad?
[Re: mcmopars]
#1319891
10/13/12 10:38 PM
10/13/12 10:38 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Work as a tech for 30 years and youll see everything.Ive seen them leak,fall apart,not hold even a pound of pressure and some not relieve the pressure when they should.I have the same cap on my 65.Been on 4 years and no problems.Check the seal and make sure its not torn.Mine fits real tight on the rad.Rocky
Chrysler Firepower
[Re: therocks]
#1319892
10/13/12 10:58 PM
10/13/12 10:58 PM
Posts: 15,487 Florida
scratchnfotraction
![](/ubbthreads/images/graemlins/iagree.gif)
make sure it is the correct cap also. vented for recov bottle system, non-vented for non recov system.
most times it is the upper or lower rubber seals that wear and leak from age on my junk.
[Re: MidPenMopar]
#1319895
10/14/12 07:12 AM
10/14/12 07:12 AM
therocks
Niles , Ohio
Correct the pressure raises the boiling temp.Just make sure the rad isnt over full also.Sounds like you have had the car for a while and you know that the early ones run about an inch or so down in the rad if not a recovery system.Most shops have a cap tester.It takes about a minute to test them.Usually they will do it free if you ask.Rocky
Chrysler Firepower
[Re: therocks]
#1319896
10/14/12 11:58 AM
10/14/12 11:58 AM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Over filled??? I never knew you could over fill the radiator. So where would be the correct fill level. Right now i am a little over the top of the rows. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: RSNOMO]
#1319898
10/14/12 12:54 PM
10/14/12 12:54 PM
MidPenMopar
'Sounds like you have had the car for a while and you know that the early ones run about an inch or so down in the rad if not a recovery system'
No mine is a recovery system, so that would assume to fill it further up near the neck.
[Re: MidPenMopar]
#1319899
10/14/12 12:57 PM
10/14/12 12:57 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
Fill it ALL the way Stu.
[Re: MidPenMopar]
#1319900
10/14/12 01:00 PM
10/14/12 01:00 PM
therocks
Niles , Ohio
Pre I believe 71 all systems were non recovery.They run down about an inch or so.Your cap should be the recovery type if you have a recovery system.My 65 runs just over the cores.Over fill and it will come out the overflow to the catch can I installed.It used to come out the over flow hose when over filled.Rocky
Chrysler Firepower
