dry sump systems? 2 stage-- 5 stage #1319604
10/13/12 11:04 AM
10/13/12 11:04 AM
where its cold and white durin...
2QUICK4U Offline OP
2QUICK4U  Offline OP
whats the purpose of running a 5 stage verses a 2 stage?
Re: dry sump systems? 2 stage-- 5 stage [Re: 2QUICK4U] #1319605
10/13/12 11:17 AM
10/13/12 11:17 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
More pickup points, quicker oil recovery.
And maybe more vacuum inside the engine, maybe someone can verify this.
I have a 5 stage 3 in the pan and one in the cam tunnel.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: dry sump systems? 2 stage-- 5 stage [Re: 2QUICK4U] #1319606
10/13/12 11:30 AM
10/13/12 11:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just more pick up points and more vac... I run a
3 stage(2 in the pan and 1 in the intake valley, my
R3 block is solid in the valley)... with mine I get
12" of vac which is all I want... I have heard if you
run too much vac you pull the oil off the bearings
Also some call the pump section as 1 .. I dont... I
just call the suction sections ... as in mine has 3
suction section and the pump section
