What type of front seats are you using in your rod????? #1319408
10/12/12 12:31 PM
10/12/12 12:31 PM
Endicott, NY, USA
crazyjjk Offline OP
crazyjjk  Offline OP
Endicott, NY, USA
Just wondering what type of front seats people went with in their street rod? Temporarily I have buckets from an Isuzu Pup in mine. Not very comfortable and just wondering what some of you went with for front seating/
Re: What type of front seats are you using in your rod????? [Re: crazyjjk] #1319409
10/12/12 02:54 PM
10/12/12 02:54 PM
PA
W
Waynes48 Offline
Waynes48  Offline
W
PA
I installed buckets from a 1995 Pontiac Bonneville in mine. Extremely comfortable seats, and they look good in the car too.
Re: What type of front seats are you using in your rod????? [Re: Waynes48] #1319410
10/12/12 04:41 PM
10/12/12 04:41 PM
dogdays Offline
dogdays  Offline
1990s Taurus SHO or other ford product buckets are pretty good and should be findable.
R.
Re: What type of front seats are you using in your rod????? [Re: dogdays] #1319411
10/12/12 08:19 PM
10/12/12 08:19 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i like the dodge van short back seats for the utilitarian look----similar to the 64 hemi race car seats---all that cool fabric and high back seats just dont say hot rod no matter how cheap you got them....bob
Re: What type of front seats are you using in your rod????? [Re: savoy64] #1319412
10/12/12 10:49 PM
10/12/12 10:49 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Depends on the year your rod is, with cars before 37, the front seat area is very narrow. You need a set of buckets that are narrow, and the seats will still touch each other and also touch the door panels. My 35 Dodge sedan had a set of buckets out of an 80s Tempo, they were comfortable and worked well.
When you get to 37 or newer, the width increases and seating options get bigger. My 48 Plymouth coupe has a bench seat out of a Dakota.
Seating in trucks tend to need to be more upright and have short backs. The worst seats I ever put in my 54 Dodge pickup were buckets from a mid 80s 5Th Ave! The seats themselves were great, but the backs laid back too much and were too high to fit under the rear window sill. My knees were almost in the dash, a very uncomfortable ride if longer then a 1/2 hour or so. I replaced those with a set of low back buckets from a swap meet. After removing the head rest, the seat backs fit under the rear window sill and could be slid back, giving me a few inches before my knees would have been against the dash, much better. My 50 got a set of short back buckets from a front drive Mopar (I think they were from an E Class car) with the adjustable backrest. Then I added an ammo box between the seats for storage. With the 48 & newer Dodge trucks, the width of the seat is generally not an issue, the angle of the back rest and the height of the seat back are issues. Buy accordingly. Gene
Re: What type of front seats are you using in your rod????? [Re: poorboy] #1319413
10/12/12 10:53 PM
10/12/12 10:53 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Dakota bench it was free but it fits my 39 perfectly.
Re: What type of front seats are you using in your rod????? [Re: crazyjjk] #1319414
10/13/12 09:28 AM
10/13/12 09:28 AM
E
earlymopar Offline
earlymopar  Offline
E
What poorboy said is true and it also depends on the appearance or style you're after.
For my 37 pickup, I wanted something that appeared as stock as possible and, I didn't want to spend a small fortune getting it. I bought a bench seat frame from the wrecking yard that I removed from a Mazda B2200 pickup ($15). I liked it because had a nice tube steel structure and was close to being usable as it was. Then because of the narrow width and taper of my cab, I cut the seat width and narrowed it, followed by "pinching" it to get the same taper as my cab. It worked out very well and looks great.
Re: What type of front seats are you using in your rod????? [Re: earlymopar] #1319415
10/13/12 11:50 AM
10/13/12 11:50 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have a set of 3rd gen. dakota buckets to go in my desoto. it was an extended cab so they tip forward so i can get in the back seat. not in there yet though.
Re: What type of front seats are you using in your rod????? [Re: 65rbdodge] #1319416
10/13/12 09:07 PM
10/13/12 09:07 PM
pensacola, fl
53fopar Offline
53fopar  Offline
pensacola, fl
Using front seats from '99-'02 Tahoe/Escalade/Suburban. They have the seat belts built in. Also late 90's Trailblazer.
Re: What type of front seats are you using in your rod????? [Re: ] #1319418
10/15/12 12:03 PM
10/15/12 12:03 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I used power seats from a grand cherokee and a console from a durango. They were cheap junkyard finds. The power seats makes getting the right angles easy.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: What type of front seats are you using in your rod????? [Re: rattler] #1319419
10/16/12 02:38 AM
10/16/12 02:38 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
looking for a set of buckets,,not sure if i want a head rest or not for my 40 coupe,,i hate the bucket seat look when they touch each other may as well put a bench seat in it,,,my factory seat isnt to comfortable on longer rides,,,
im thinking late 80s mustang or early 90s T BIRD lots of after market for factory seat covers and color choices,,and they seem to measure perfectly to fit my 40 coupe and have some sort of narrow console
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: What type of front seats are you using in your rod????? [Re: fstfish66] #1319420
10/16/12 11:24 PM
10/16/12 11:24 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A 40 should have plenty of room to put a nice set of bucket seats into, its the mid 30s and earlier that is too narrow. Gene
Re: What type of front seats are you using in your rod????? [Re: poorboy] #1319421
10/17/12 10:10 PM
10/17/12 10:10 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Pontiac Fiero seats in my '33 coupe.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: What type of front seats are you using in your rod????? [Re: 5wndwcpe] #1319422
10/18/12 09:10 PM
10/18/12 09:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Narrowed the bench from a 79 Newport for my 38 Plymouth, took about 4" out.
Don't be the exception.
Re: What type of front seats are you using in your rod????? [Re: Supercuda] #1319423
10/18/12 09:51 PM
10/18/12 09:51 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
99 Intrepid buckets in my 34 coupe.
Re: What type of front seats are you using in your rod????? [Re: B1arno] #1319424
10/23/12 07:09 PM
10/23/12 07:09 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
another popular seat is the 60,s T-bird buckets (lowback) with the curved love seat rear---one of my friends put a set in his 35 ford slant back--the rear seat is in 2 sections allowing you to narrow them down to fit....bob
Re: What type of front seats are you using in your rod????? [Re: savoy64] #1319425
10/24/12 03:51 PM
10/24/12 03:51 PM
Ruther Glen, Virginia
DanteGray Offline
DanteGray  Offline
I have 2002 black dodge Neon seats in my duster, $40 at pick-a-part
Re: What type of front seats are you using in your rod????? [Re: DanteGray] #1319426
10/24/12 09:19 PM
10/24/12 09:19 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
i am using a thirdrow seat from a 1999 chrysler town&country minivan in our 41 willys.that is the only year with the fold down center armrest.will mount two cupholders in the back of that and when it is flipped up you won`t see them.cut the rollers off and bolted alum angle to it to mount to the floor.still adjustable for diff drivers and seatback flips forward for access to behind seat area.paid 50 bucks at salvage yard.
Re: What type of front seats are you using in your rod????? [Re: webemopes] #1319427
10/24/12 09:32 PM
10/24/12 09:32 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
99 Sebring buckets.
Re: What type of front seats are you using in your rod????? [Re: crazyjjk] #1319428
10/25/12 12:35 AM
10/25/12 12:35 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I was intent on trying a bench seat in my 40. I like the looks of a bench, but I have two extremely comfortable Sebring bucket seats in my motorhom that I will eventually part out, and when measuring... it looks like they are just the right size to LOOK like a bench seat but be more of a "split bench" so each side is adjustable.
I'm not sure what to do to be honest.
I've got the car in a shop that should be usable in another month at most so I'm gearing up to start doing SOMETHING. I hope anyways...
CrAzYMoPaRGuY
