I take it is a 5.2 or 5.9 eng ? First if it did not do it before the exh change then you need to make sure the exh did not change the exh back pressure to much. Most of the ECR valves on that year have a solenoid the PCM works but they also need so much exh back pressure to close a valve inside the EGR so it will work and open when it should. EGR is like a poor mans octane booster as it lowers combustion chamber temps. Many cars and trucks as soon as the EGR is unhooked they start pinging from to high combustion chamber temps. When it puts the burnt exh gasses back into the cylinders it wont burn since it is already burnt gasses and it keeps the cylinder from starting more then one flame front and keeps the cyl temps lower.
That said they also have a problem with the gasket on the bottom of the intake leaking and sucking oil into the cylinders and building up carbon hot spots in the cylinder chambers. Sometimes you can tell but looking down in the intake to see if it has a bit of oil laying in it. Just open the throttle body all the way or pull the throttle body off to get a good look. If it is leaking you have to pull the intake and replace the gasket on the bottom of the plenum. Then sometimes you can run combustion chamber cleaner through the eng to try and break up the carbon. If its real bad you may have to pull the heads and clean the carbon.
But I would make sure your EGR valve is working first. The PCM can set a code as it will test the EGR under certain driving conditions as when it opens the EGR valve the 02 sensor will show leaner and the PCM will look for a change in the short term memory right away. But sometimes it takes alot of driving to meet the right terms for the PCM to run the test. If you know anyone at a Mopar dealer they can check it real easy with the scanner. Ron
