Re: Improvements from Custom Carb?
[Re: BradH]
#1318492
10/10/12 05:33 PM
10/10/12 05:33 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Few years back I tried 3 custom carbs on a well sorted out 416 combo I had ran the car with a 1025rs race demon for quite a while. I tried a 750 and 1000 cfm pro systems 4150 carb and a 1100 pro systems dominator. The dominator was a couple or three hundreds better than the race demon, and the two 4150 carbs were tenth to tenth and a half slower. I bought the dominator and sold the race demon thinking I could get even more out of the custom dominator than initial testing showed. I never did. I suspect a real well tuned and sized. carb won't be beat by much if any
[Re: BradH]
#1318494
10/10/12 07:09 PM
10/10/12 07:09 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Reading this with interest, probably going to put the 950 HP on my Dakota this winter, I was thinking about sending it out to Jesse Bigs first.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#1318495
10/10/12 08:07 PM
10/10/12 08:07 PM
Posts: 12,421 Taxes & Virus's R-US, NY
Dragula
Here's my impressions.... If you have a well sorted out carb, and its close to optimal for the application, air/fuel is just that, air & fuel. Spending big money on a custom unit thinking you left Hp on the table to be had isn't likely. The engine still wants the same A/F ratio unless you changed somthing else or your carb has a restrictive choke horn or another issue. The only way it make more hp is getting more air and fuel in togather. Now, lets say you have a new engine, and no carburator, a custom one will get you a lot closer out of the box a lot quicker from my experience. Then its worth it because your not spending as many TNT sessions finding the correct A/F and squirter shot for your combo. Now as far as carburator sizing vs. HP, there is an article titled "Tall Tails" by Steve Dulcich that does away a few of the myths, but in his test, low end was limited to 3200rpm or above...With the big carburators making more power in the upper rpm, but not sustaining anything below 2600rpm...This is where I learned the advantage of annular boosters. They make a large carb effectively 200cfm smaller in responsiveness. If you want a big carb for the max hp, and you want good low end for driveabliilty, then you need a carb that offers annular boosters, and is bigger than what you currently use without being too big. I used this to run a 800cfm annular quick fuel carb on my mild 360 street engine. It actually took a little bit of time with the efi to achieve the same results at the drags. Also note, this is before the new SV1 style carb as well... http://www.moparmusclemagazine.com/parts/engine/mopp_0111_demon_carburetor_dyno/viewall.html
[Re: Dragula]
#1318497
10/10/12 09:00 PM
10/10/12 09:00 PM
Posts: 12,326 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I don't usually see much difference in the "pro" carbs and the ootb carbs at the track. ASSUMING that the ootb carb is correct for the application and a reasonable amount of track tuning is done. For street cars though, I have seen some pretty dramatic improvements in idle, light throttle response and cruise. Tayloring the part throttle transitions for each individual engine seems to be a lot more difficult than getting the WOT mix right. ![](/ubbthreads/images/graemlins/Twocents.gif)
Master, again and still
[Re: DaveRS23]
#1318498
10/10/12 09:03 PM
10/10/12 09:03 PM
Adobedude
New Mexico
All I'm looking for is WOT...With the stock PCM and my cam I've gotten pretty good at brake stalling my truck onto the trailer at 4K RPM.. Everyone around me runs away though... ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Dunnuck Racing]
#1318500
10/11/12 12:50 AM
10/11/12 12:50 AM
Posts: 5,875 communist bloc of new jersey
jamesc
Anyone that truly thinks a WELL BUILT custom carburetor does not make more power than a "dialed in" box carburetor has never used one. I have spent enough time tuning several different ones to see a real difference. After several days with A/F and egt readings dialing in different carburetors,I bolted on a Dale Cubic that was not built for my combo and saw decent gains. The next best I saw was an SV1 with A little tuning. There is way more to it than just air and fuel ratio. Droplet size,proper for the fuel and rpm range comes into play. I don't claim to have all the answers,just sayin'! Keith
i don't think anyone would dispute that, however most applications will perform well with a properly selected and tuned shelf carburetor...and i don't mean one that's been ham fisted by some backyard carb guru i mean new never had fuel in it. if you're going for every last bit of performance then a custom carburetor will be better but in most cases that amount of money will yield better performance if it's invested elsewhere.
holley does have some idea of how carburetors should work and have been making improvements to their line.
[Re: jamesc]
#1318501
10/11/12 01:35 AM
10/11/12 01:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The only way these carb gurus can make a carb RIGHT for your engine is to have a wet flow bench with a bell on it.... I did carb flow work (for a short time) before I started the injection work at Chrysler... if they dont have that equipment its their BEST GUESS ![](/ubbthreads/images/graemlins/wave.gif)
