5.7 hemi conversion question #1318475
10/10/12 03:46 PM
10/10/12 03:46 PM
louisville ky
67gtxclone Offline OP
louisville ky
anyone who has made this conversion can you tell me what size hole i should cut in the firewall for the computer cables and where in the firewall would be best location thanks
Re: 5.7 hemi conversion question [Re: 67gtxclone] #1318476
10/10/12 04:40 PM
10/10/12 04:40 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I just drilled a hole a bit larger than the cable and sized it to use a body plug to take up the slack in the hole. Don't remember the size though, maybe 2".
-Daty
Re: 5.7 hemi conversion question [Re: Daty Rogers] #1318477
10/11/12 01:14 AM
10/11/12 01:14 AM
808CUDA Offline
808CUDA  Offline
Hmmmm.... If I recall correctly the hole was closer to 1.25" but this was like 4 years ago. Call Tony or Chris Squier at hotwireauto.com and he will tell you.
As for location, I did it on the lowest I could on the passenger side firewall to hide the wiring and keep it clean looking.
