Re: What fuel Mileage do you get with your 5th Ave?
[Re: QuickDodge]
#1317802
10/09/12 05:15 PM
10/09/12 05:15 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
The origina EPA estimates were 16 mpg city and 22 highway for a 1985 model year 5th Avenue. The EPA has since revised all of their mileage figures. The new mileage figures are 15 city and 20 highway.
It's interesting to compare the 5th Avenue's mileage figures with the 1985 Diplomat POLICE car's mileage. (The civilian and police cars are rated separately) The EPA's original estimates for the police car were: 13 mpg city and 15 mpg highway. The EPA's revised figures are: 11 mpg city and 14 highway.
The civilian Diplomat's mileage ratings are identical to the 5th Avenue. So the question is why did the police Diplomat use so much more fuel than the civilian cars?
they have an 18 gallon tank.
dippy cop cars had a 360 top end (heads, intake, and 4bbl carb)
the 2.21 rear gear kills mileage in town...I could usually get 13 in town stock. best I ever got was 25mpg going to detroit and back, and that was with the cruise set near 80mph. set the cruise at 65-70 and mileage was about 23. that was stock. mixed driving was pretty consistant at 18mpg....once I modded for power, mileage went down, even with the A500 OD tranny. never took it on a full highway trip in it's last incarnation (mag headed 318 roller cam motor, A500, 3.55 rear gears), but it was very consistent at 17.5mpg in mixed driving, so it probably could've knocked down 22-23 all highway, and probably could have been even better with a t-quad or one of the new street demon t-quad clones over the 600 eddie AFB I had....a FAST EZ_EFI would have been neat to try, too...
that said, my '11 charger R/T is faster, more comfortable, and handles better, and for the 8k miles I've owned it, the same commute I averaged my rock steady 17.5mpg in the modded 5th, I'm averaging 23mpg...
a 5.7/A580 would be sweet in one if you could pick one up cheap enough. would require significant mods to fit the tranny in. a 5.7/A833OD would also be a fun combo, coupled with a 3.23 rear, and would probably knock down 25mpg highway....
[Re: 76dodgeboy]
#1317805
10/10/12 01:50 PM
10/10/12 01:50 PM
patrick
Grand Haven, MI
well, 195/75R15's are 1/2" shorter than the stock 205/75R15's...it's 2% difference. so....if 75mph was 2000 RPM with the stock tires, it would be 2040RPM. negligible difference. assuming a dead-nuts speedo and odo with stock tires, 60mph indicated would actually be 58.9mph. 100 miles indicated driven would actually be 98. so it would skew your gas mileage calculations the other way (overestimating miles driven).
don't trust the gas gage. on my 5th ave with the 360 in it, it would go 150 miles to 1/2 tank, and be near E and the low fuel light would come on at 225-240 miles, and take about 15-16 gallons to get to full. with the mag headed 318, I typically got 280 miles before the low fuel light, and it would take about 16 gallons to fill, with 180 miles on the trip odometer at 1/2 tank...
[Re: patrick]
#1317806
10/10/12 10:10 PM
10/10/12 10:10 PM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
How my 5th is set up: 318, Performer intake/1406 carb, HEI ignition, lock up trans with a Superior TF-TC shift kit (mainly to raise the lockup speed), 8 3/4 rear with 2.94 gears and 215/70R-15 tires. When I did a daily 80 mile round trip commute, it would usually get around 22 MPG at 65, a little less at 70.
Eric
[Re: 76dodgeboy]
#1317810
10/11/12 08:49 AM
10/11/12 08:49 AM
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
When I first bought my 5th, my friend that I bought it from had an old Edelbrock SP2P 4bbl manifold on it and a Holley 4360 450cfm (an economy replacement for Quadrajets) on it. It did about the same for milage. Had great low end torque with the small runners though.
Eric
[Re: 76dodgeboy]
#1317813
10/11/12 05:57 PM
10/11/12 05:57 PM
Posts: 15,487 Florida
scratchnfotraction
the primary triple venturie on a spredbore is why a q-jet/thermobog do so well on the mpg. small primarys for great throttle responce,triple venturies do better at atomizing the fuel into the air mix. very tunable with 3 step needles and jets(eddies are 2 step needles) when you are on the 2ndarys there is no consern with mpg. it is all about the s**t and get. work on everything from a 273 to a 440 for street duty and mild performance. not to mention they sound kool when they open up and dont have any bogs to them. I can stomp my 318 with q-jet from a 650 rpm idle to a full WOT run with no bogs,gets 19+ mpgs in the truck if i drive like "Ma & Paw kettle" cant wait to get the q-jet from the 454 chebby set up for the 440 truck myself. I am shooting for anything over 10 mpg with it. stock 440,q-jet,3.23 should do a little better than the eddy 600cfm with 3.91 gear. I am just glad I get 19+ with the 85 truck as a daily drive 80 miles perday round trip.
[Re: 76dodgeboy]
#1317815
10/11/12 09:12 PM
10/11/12 09:12 PM
scratchnfotraction
may need tuning/rejetted but would work as it is a SB thermobog. it will have the smaller primary bores compaired to larger primary bores of a BB thermobog. may need the same tuning with any q-jet or other carbs brands as well,if you want the most from it. I use a chebby 327 q-jet on my 318,very close on jetting and tuning. the q-jet from the 454 should be in the ballpark for the stock 440. dial them right in with a vac gauge and get the 2ndary airdoor adjusted just right and no bog on the transition tip in. and the q-jet is cheap to rebuild and mod o fry. if you stay with a chebby carb the fuel inlet is to the side,the GM/GMC/pontiacs are front feed and can interfear with the rad hose/t-stat location. you can get the short q-jet inverted flare fitting and ditch the filter to shorten it up some. grind the chebby throttle lever off and tac a mopar q-jet lever on and all the stock linkage works with the early non emissions chebby q-jets with looking for a carb. the carbs that have 704**** as the first 3 digets in the # are the bestest...ones with 1704*** or next bestest when junkyarding for them. if you know how and can fine tune a thermobog it may out do the q-jet. q-jet areless work tuning. i dont get the how to on thremobogs
