Leaky Valve cover gasket #1317289
10/08/12 02:42 PM
10/08/12 02:42 PM
Md
E
EK2Runner Offline OP
E
Md
Just got my Dads 383 RR back after selling it to him 20yrs ago . Noticed when i got back home with it the right cover is leaking like a sive . Question is , what type is best to use and how (blue rtv or no rtv ?) ? I had a friend tell me they now make some type of composite gasket ? Thanks in advance !
Mike
It's a Mopar thing , If you have to ask you wouldn't understand
Re: Leaky Valve cover gasket [Re: EK2Runner] #1317290
10/08/12 05:02 PM
10/08/12 05:02 PM
scratchnfotraction Offline
yes,felpro has a nice hard thick set you have to really crank down on to get it to crush and seal good.
i used them on my 440. also used some stock bolts with the triangle bolt hold downs. this helps on the corners.
I made sure the VC rail was striaght and the holes not puckerd. then wiped head and Vc down with brake clean. use some mopar black ATF/RTV sealer and let cure over night.
sealed right up and been a yr or more with no leaks.
Re: Leaky Valve cover gasket [Re: scratchnfotraction] #1317291
10/08/12 06:55 PM
10/08/12 06:55 PM
Md
E
E
Md
Thanks for the info . Just got back from Napa , they had the set you were refering to . Bought some black rtv gasket sealant also . Tomorrow i'll run over to the local speed shop to see if they have those brackets . Napa had them but they were chrome , see if i can find some steel one's and paint em orange . Thanks again for the help !
Re: Leaky Valve cover gasket [Re: scratchnfotraction] #1317292
10/09/12 02:48 PM
10/09/12 02:48 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Amost everytime, it's the valve cover's fault.
A straight sheet metal cover or a cast cover, rarely leak.
Does your PVC / breather system work?
Re: Leaky Valve cover gasket [Re: Magnum] #1317293
10/09/12 05:52 PM
10/09/12 05:52 PM
Md
E
E
Md
Yes , Appears to be working fine , i havent noticed anything out of the ordinary .
