Page 3 of 3 1 2 3
Re: 572 hemi won't start and run [Re: HR3128] #1316685
10/08/12 10:02 AM
10/08/12 10:02 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
On an msd setup the coil doesn't get a 12v wire it gets the two coil wires out of the box. The coil gets sent a capacitor diacharge (big jolt) for each spark. It's the same reason you can't run a standard tach off a coil fired by msd- you use the tach wire off the box.
Re: 572 hemi won't start and run [Re: HR3128] #1316686
10/08/12 10:57 AM
10/08/12 10:57 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I think the 1st thing to do is to separate the ignition from the relay. Run a wire from the battery to one side of your ign toogle switch, then from the other side of the sw to the MSD red wire.
Sounds like the relay isn't staying pulled in when the start button is released. The small red wire is the "ON" for the box. The large red wire is for the power to the box for the actual spark generation..
If you like drag racing, support your local track.
Re: 572 hemi won't start and run [Re: CHAPPER] #1316687
10/08/12 11:16 AM
10/08/12 11:16 AM
ohio
dbran451 Offline
dbran451  Offline
ohio
Make sure you have a good ground to the motor not the stand and don't ask.
Re: 572 hemi won't start and run [Re: dbran451] #1316688
10/08/12 12:58 PM
10/08/12 12:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does anyone know which wire is the + on the dist wires
coming from the 7AL box... violet or green
thanks
EDIT
Never mind I found it... violet is +
Re: 572 hemi won't start and run [Re: HR3128] #1316689
10/08/12 03:55 PM
10/08/12 03:55 PM
Maryville TN
68528hemi Offline OP
Maryville TN
the cam is for a 440 NOT A HEMI. valves open and close diffrent on a hemi lunnati sent me the wrong cam, they won't make it right. i guess i'm out 330.00 bucks
Re: 572 hemi won't start and run [Re: 68528hemi] #1316690
10/08/12 04:47 PM
10/08/12 04:47 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
the cam is for a 440 NOT A HEMI. valves open and close diffrent on a hemi lunnati sent me the wrong cam, they won't make it wright. i guess i'm out 330.00 bucks
What the...??
How'd you find that out?
Re: 572 hemi won't start and run [Re: 68528hemi] #1316691
10/08/12 04:50 PM
10/08/12 04:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well that sucks.... how did you figure that out
Re: 572 hemi won't start and run [Re: MR_P_BODY] #1316692
10/08/12 05:01 PM
10/08/12 05:01 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Ugh: Was it pumping air out the carbs?
Sheldon
Re: 572 hemi won't start and run [Re: cudadoug] #1316693
10/08/12 05:27 PM
10/08/12 05:27 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
What the...??
Probably after looking pretty hard at the cam card...
Re: 572 hemi won't start and run [Re: 68528hemi] #1316694
10/08/12 05:45 PM
10/08/12 05:45 PM
pa
572charger Offline
572charger  Offline
pa
ouch that hurts !! yeah the 1st lobe on a hemi cam is the intake, 440 its the exhaust !who degreed the cam in ??
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 572 hemi won't start and run [Re: 572charger] #1316695
10/08/12 05:49 PM
10/08/12 05:49 PM
HR3128 Offline
HR3128  Offline
Think any valves got bent????
Re: 572 hemi won't start and run [Re: HR3128] #1316696
10/08/12 05:52 PM
10/08/12 05:52 PM
Maryville TN
Maryville TN
i sure hope not just got the heads back fro mch.
Re: 572 hemi won't start and run [Re: RUNCHARGER] #1316697
10/08/12 05:54 PM
10/08/12 05:54 PM
Maryville TN
Maryville TN
yes it was pumping air. i thaught what in the world is going on.
Re: 572 hemi won't start and run [Re: 68528hemi] #1316698
10/08/12 06:04 PM
10/08/12 06:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Scan and post the cam card you never know who may be intersted??
Re: 572 hemi won't start and run [Re: Dodgem] #1316699
10/08/12 06:43 PM
10/08/12 06:43 PM
Maryville TN
Maryville TN
Ok they are going to custom grind one for me. And take the the 440 one back. THANKS for all the replys.
Re: 572 hemi won't start and run [Re: 68528hemi] #1316700
10/08/12 07:16 PM
10/08/12 07:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Dam I don't think anyone of us would of guess that !
Re: 572 hemi won't start and run [Re: 572charger] #1316701
10/08/12 07:33 PM
10/08/12 07:33 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
cam must not have been degreed in. i think it would have been caught there.
Re: 572 hemi won't start and run [Re: rickraw] #1316702
10/08/12 07:42 PM
10/08/12 07:42 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yea I don't know that could of come out right ?
Re: 572 hemi won't start and run [Re: 68528hemi] #1316703
10/09/12 12:35 AM
10/09/12 12:35 AM
Welcome to the wondeful world of custom engine building and Hemiroid motors So much for lining up the dots, HUH
Page 3 of 3 1 2 3
