572 hemi won't start and run
#1316645
10/07/12 04:04 PM
10/07/12 04:04 PM
Posts: 59 Maryville TN
68528hemi
Maryville TN
just finshed my new 572 hemi. Engine is on a break in stand. It has a msd 6al and distributor. power is going threw the distributor ask my left hand ouch. with the number piston at tdc I made sure the number 1 valves were closed and set the distributor button pointing at number 1 going counter clockwise. I even flip the distriburtor thinking i could be 180 i got the same response it acts like it is still out of time. I even went 1 notch to the right and left still acts funny. my valve lash is right on the money. it will turn over but not run my cam is 2 degrees advanced and is 10 to 1 engine. I have a electric fuel pump and regulator and is set on 6 pounds. everything on the engine is new. the onley the i can think of is maybee oil is getting under my spark plug tubes and messen with my plugs . Plugs are autolite 65. please help
Re: 572 hemi won't start and run
[Re: hemi-itis]
#1316654
10/07/12 06:09 PM
10/07/12 06:09 PM
Posts: 3,695 nc
emarine01
nc
You need 2 thing to fire it up,spark & fuel.Did you set the floats on the carb{s}?Is ther fuel squiting in when you "pump"it?If so,then it's the spark timing
Compression would be the third one but we wont talk about that one yet ![](/ubbthreads/images/graemlins/frog.gif)
[Re: emarine01]
#1316655
10/07/12 06:15 PM
10/07/12 06:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
yep.... that sure counts.... otherwise its just a fire and not a explosion ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 68528hemi]
#1316657
10/07/12 06:20 PM
10/07/12 06:20 PM
MR_P_BODY
its 10 to 1
Thats not what we're saying... whats the cranking pressure... and 10:1 is just a math figure... the cam will dictate what the pressure is ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 68528hemi]
#1316658
10/07/12 06:24 PM
10/07/12 06:24 PM
Posts: 3,695 nc
emarine01
nc
its 10 to 1
I hope so ![](/ubbthreads/images/graemlins/thumbs.gif)
