440 Fuel Line Routing #1316570
10/07/12 11:22 AM
10/07/12 11:22 AM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Geting ready to bend up a 3/8" fuel line between the fuel pump and carb on my 440 Challenger. I have a Holley carb and carter fuel pump. Does anyone have a pic of the correct line configuration? I know it snakes around the alternator somehow, and I'd like to come as close to stock-look as I can. Thanks in advance
Re: 440 Fuel Line Routing [Re: 70VERT] #1316571
10/07/12 11:33 AM
10/07/12 11:33 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
doesn't it go from the pump up behind the alt next to the block and poke up by the dizzy? that's how i routed mine on my 69 road runner.
Re: 440 Fuel Line Routing [Re: mikemee1331] #1316572
10/07/12 12:39 PM
10/07/12 12:39 PM
If you don't have any lines and don't mind aftermarket, get the fuel lines from Greg at Fabulous Fabrications. Dirt cheap and not worth the hassle to make them on my own!
I've had them on two cars now and the fit is absolutely perfect!
Here is an example:
Re: 440 Fuel Line Routing [Re: 70VERT] #1316573
10/08/12 07:57 PM
10/08/12 07:57 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Are you going to add a fuel filter near the stock location ??? Believe it or not the hardest piece to make is the short one that goes from the pump to the filter...It's bent pretty hard and you need a short radius bender to do it...The longer one that comes up behind the alt and around{in front} of the distributor is'nt too bad just alot of bending/fitting...And now for the ancient tubing benders secret handshake.. .Fill the line with sand and tape the ends before you bend it...It'll keep the line from collapsing while you put the tight bends in it...Just make sure you flush/clean it out well after the fun is over...
Re: 440 Fuel Line Routing #1316574
10/09/12 08:33 AM
10/09/12 08:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Here is an example:
buddy of mine just bought a set, and I will say for what he paid you can't do it yourself at least and have it look and fit as good.
Coming soon!!!!
Re: 440 Fuel Line Routing [Re: Mr.Yuck] #1316575
10/09/12 08:57 AM
10/09/12 08:57 AM
WV
JohnH Offline
JohnH  Offline
WV
Got mine from IN LINE TUBE pre bent,,, perfect fit..no hassel
Re: 440 Fuel Line Routing [Re: JohnH] #1316576
10/09/12 10:02 AM
10/09/12 10:02 AM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
Fab-Fab on mine!! BTW, does anyone have his contact info? I need another set made.
