Generally what happens is ... you hit the pedal and
it loads the diff which hits the tires and tries to
rotate the diff (pinion up).. the front of the spring
is trying to lift the body(which is really trying to
push the rear end down)... as it is lifting its also
trying to move forward... if it can get under the
weight line it will continue to lift and move forward...
so now comes the front part of the car... if you allow
the front to lift, the car will be moving weight to
the rear of the car... if it doesnt move the weight
rearward you only have the rear weight on the tires
and on most cars the front end is heavier than the
rear so thats alot more weight to help plant the tires
so thats the general of whats happening(I didnt get
into the car trying to spin the diff in the car or
any of that stuff)remember that old scientific thing
of where there is a ACTION there is a equal and opposite
REACTION..... it applies to EVERYTHING
