Electronic voltage regulator to fit 67 factory housing #1316446
10/07/12 12:41 AM
10/07/12 12:41 AM
Arizona
az426john Offline OP
Arizona
Does anyone make a good electronic voltage regulator that will fit under the old style (67) factory housing?
Thank you for your help in advance.
Re: Electronic voltage regulator to fit 67 factory housing [Re: az426john] #1316447
10/07/12 01:08 PM
10/07/12 01:08 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
The last ones I bought from the parts stores were solid state electronic several years ago.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Electronic voltage regulator to fit 67 factory housing [Re: az426john] #1316448
10/08/12 12:03 PM
10/08/12 12:03 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
There is a moparts member who sells them with the vintage style cover.
Autozone has them with a short cad plated cover but it be modified to look stock.
ebay also sells them.
http://www.ebay.com/itm/Mopar-Correct-Lo...8c3&vxp=mtr
http://www.ebay.com/sch/i.html?_trksid=p...3&_from=R40
