Mopar mini starter suddenly doesnt work #1315970
10/05/12 09:14 PM
10/05/12 09:14 PM
Mi.
G-Money1320 Offline OP
Mi.
I was trying to get my car out of the trailer last weekend after sitting in there since the Norwalk Mopar event and the starter just clicked like the battery was dead. After a quick charge it turned over real slow and erratically like the motor had a spun bearing. I never had an issue with this starter or any indication of it going bad and it was purchased brand new, Could it have gone bad all of a sudden like that?? Or could there be something else that might be causing the symptoms? Battery is good. Thanks.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Mopar mini starter suddenly doesnt work [Re: G-Money1320] #1315971
10/05/12 10:15 PM
10/05/12 10:15 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Is there a small plastic cover on top of the starter? If so, pop it off and check the nuts for being loose.
Yeah, it's got a smallblock.
Re: Mopar mini starter suddenly doesnt work [Re: 340B5] #1315972
10/05/12 10:28 PM
10/05/12 10:28 PM
Mi.
Mi.
No cover, it is the style with the slide plug for the small wire.
Re: Mopar mini starter suddenly doesnt work [Re: G-Money1320] #1315973
10/06/12 09:41 AM
10/06/12 09:41 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Clean battery terminals and check ground to chassis.
Re: Mopar mini starter suddenly doesnt work [Re: cgall] #1315974
10/06/12 10:54 AM
10/06/12 10:54 AM
ill
dennismopar73 Offline
ill
you need to take the starter off the motor, take the selnoid aprt, fix the contacts!!
a little aggravating, but will save you life time of issues
Re: Mopar mini starter suddenly doesnt work [Re: cgall] #1315975
10/06/12 01:41 PM
10/06/12 01:41 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
this is one of the typical causes.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Mopar mini starter suddenly doesnt work [Re: dennismopar73] #1315976
10/06/12 10:28 PM
10/06/12 10:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Greg, my bet this is the fix. I'd be happy to take a look at it for you.
Doug
Re: Mopar mini starter suddenly doesnt work [Re: dvw] #1315977
10/06/12 11:15 PM
10/06/12 11:15 PM
Mi.
Mi.
Ok Doug, im hoping to get the car pushed out of the trailer tommorrow and start pulling the starter out. The battery connections are clean as I clean them up before hooking them up. The starter never even gave me an indication of anything wrong as it started the car just fine, even when I pulled it in to leave Norwalk. I didnt know if anyone had run into this with the mini's or not. Thanks for the input.
Re: Mopar mini starter suddenly doesnt work [Re: G-Money1320] #1315978
10/06/12 11:19 PM
10/06/12 11:19 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Pull the plugs, and make sure you didn't liquid lock the motor. Just a thought.
Re: Mopar mini starter suddenly doesnt work [Re: 340B5] #1315979
10/07/12 09:20 AM
10/07/12 09:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Before going to all kinds of work get a Volt meter.Hook it to the batt and have someone crank it.A bad battery will charge but not have enough to start the car.Ive seen new batterys that are bad.Easy to check.Just because you charged it dosent mean its good.Rocky
Chrysler Firepower
