backfire only out drivers side exhuast #1315337
10/04/12 11:13 PM
10/04/12 11:13 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
Okay guys im at my wits end on this one.
the motor is a
400 with a edelbrock dp4b intake. 1406 carb
the larger summit cam Camshaft, 1-Bolt, Hydraulic Flat Tappet, Advertised Duration 282/292, Lift .465/.488, Mopar,
long tube headers. no clue tube size.
parts store wires and coils. champion plugs. i think
older electronic ignition box. i have no clue where to start looking .any ideas?
Re: backfire only out drivers side exhuast [Re: 72d100] #1315338
10/04/12 11:19 PM
10/04/12 11:19 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
When does it backfire? Any certain speed or RPM?
Maybe one of the lobes went bad on the cam?
Re: backfire only out drivers side exhuast [Re: hp383] #1315339
10/04/12 11:23 PM
10/04/12 11:23 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
it was as idle and just a little bit above.
Re: backfire only out drivers side exhuast [Re: 72d100] #1315340
10/04/12 11:48 PM
10/04/12 11:48 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Uhhh... misfire? Bad plug? Wire? Cap? One or two wrong (hot) plugs accidentally installed? Carb loading up maybe dripping fuel into intake ports on that side? Usually when I have a backfire on one side its the carb dripping fuel from venturi boosters due to float too high or dirt in needle and seat.
Re: backfire only out drivers side exhuast [Re: 72d100] #1315341
10/04/12 11:51 PM
10/04/12 11:51 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
If it's just a minor backfire, like a pop, pop, pop, it could be a header/exhaust leak.
Re: backfire only out drivers side exhuast [Re: bobs66440] #1315342
10/04/12 11:57 PM
10/04/12 11:57 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
it was doing it a lot worse with the holley on it yesterday so I'm thinking maybe an ignition problem.
Re: backfire only out drivers side exhuast [Re: 72d100] #1315343
10/05/12 12:14 AM
10/05/12 12:14 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Make sure #5 and #7 wires are on the correct plugs.....I've never done that to a car, but I did find where somebody else did it...
Re: backfire only out drivers side exhuast [Re: Jim_Lusk] #1315344
10/05/12 12:36 AM
10/05/12 12:36 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
I have seen it done many, many, times.
Most recently with a friend who had sworn they were correct, and even had double checked.
Of course his problem was a no start issue, and most likely due to the firing order being reversed on the cap As soon as the rotation was corrected, it popped right off.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: backfire only out drivers side exhuast [Re: Jim_Lusk] #1315345
10/05/12 12:41 AM
10/05/12 12:41 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
we just fired up my buddy's challenger, he swore the wires were right, we put it on a lift, took off the driver side from the header, wld go pow after 5seconds, we took down from the lift, i sd lets look again, we had the #5 and #7 crossed.
Re: backfire only out drivers side exhuast [Re: 72d100] #1315346
10/05/12 12:51 AM
10/05/12 12:51 AM
plug, plug wire, bad ECU, vac leak. You're sure the backfire is on the one side only? I'd do a compression test tho to get a baseline to start with
Re: backfire only out drivers side exhuast [Re: cornet684me] #1315347
10/05/12 07:50 AM
10/05/12 07:50 AM
bobs66440 Offline
bobs66440  Offline
When I bought my car, the owner said it had a stubborn backfire through the carb. Been that way for the 5 years he owned it. I think that's one of the reasons he wanted to get rid of it. #4 and #6 were switched...
Re: backfire only out drivers side exhuast [Re: 72d100] #1315348
10/05/12 08:59 AM
10/05/12 08:59 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
check plug wires for connection and if they are touching/burned on headers or manifolds
Re: backfire only out drivers side exhuast [Re: terzmo] #1315349
10/05/12 09:30 AM
10/05/12 09:30 AM
scratchnfotraction Offline
what they said. check for vac leaks also.
my 440 backfires out the driver side only.
but mine is an exhast leak at the rear of the driver exhast manifold.
bang all 3 gears at WOT and let all the way off with a snap,then wait a few seconds and bang like a shotgun. then maybe a couple more if I engine break it all the way down form the WOT blast.
I did a drive by of my buddys with it in 2nd and reved up, killed the key pump the throttle,hit the key and made everyone on the carport dive for cover.
sounds like a SHOTGUN BLAST every time.I have blown muffs apart fliping the key to pop it,but the glass packs are holding up for now.
could be the 3x18 echo tips that make the bang loud.
Re: backfire only out drivers side exhuast [Re: scratchnfotraction] #1315350
10/06/12 03:21 PM
10/06/12 03:21 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
guess it could be because i just have headers with purple hornies bolted directly to them.
and i know this is going to sound dumb but the firing order is 1,8,4,3,6,5,7,2 isn't it
Re: backfire only out drivers side exhuast [Re: 72d100] #1315351
10/06/12 09:15 PM
10/06/12 09:15 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yep that is right.Check it at both that is right at both ends.It can be right at the cap but switched at the plugs.
Re: backfire only out drivers side exhuast [Re: MoparforLife] #1315352
10/06/12 10:06 PM
10/06/12 10:06 PM
remeber dist goes CCW on fire order.
you can always do a comp test to rule out a burnt valve in a cyl also.
Re: backfire only out drivers side exhuast [Re: scratchnfotraction] #1315353
10/06/12 10:25 PM
10/06/12 10:25 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
i did a little diagnostic work today and heres the even numbered plugs
Re: backfire only out drivers side exhuast [Re: 72d100] #1315354
10/06/12 10:29 PM
10/06/12 10:29 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
odd
Re: backfire only out drivers side exhuast [Re: 72d100] #1315355
10/06/12 10:37 PM
10/06/12 10:37 PM
Those plugs are shot. throw in a new set & see if it straightens out. Is that wet oil or dry carbon?
Re: backfire only out drivers side exhuast [Re: 72d100] #1315356
10/06/12 10:38 PM
10/06/12 10:38 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
So i cleaned the plugs up because they are fairly new. that old Holley just dumped tons of fuel on them. they cleaned up decent enough i put them back in.
Then i checked the cap and rotor which was practically new. i did notice some up in down play in the distributor, not sure if that's normal or not?
It seemed like when i started it it was running really good and not backfiring. I'm going to play with it a little bit more tomorrow and see
