What Sure Grip Clutch Pack? #1314926
10/04/12 09:11 AM
10/04/12 09:11 AM
St. Clair Shores, Michigan
bigsbigelow Offline OP
Option 1: http://chucker54.stores.yahoo.net/mopar834.html
Option 2: http://www.drivetrainspecialists.com/categories/posi-service-parts/products/product-5305.html
Both shops are local to me so I can pick one up today. Please elaborate on your choice. If it makes a difference to you, I drag race occasionally.
What Clutch Pack?
single choice
Votes accepted starting: 10/04/12 08:11 AM
You must vote before you can view the results of this poll.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: What Sure Grip Clutch Pack? [Re: bigsbigelow] #1314927
10/04/12 09:39 AM
10/04/12 09:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think the DTS kit is a accurate picture of what is inside the spicer 8 3/4 differential .
With the mancini kit make sure there are 2 thinner plates of the ones with the ears , some kits had the wrong plates with them all being the same size which would turn the unit into a spool basically. If it does not have them you can reuse them from your current diff, the thin plate should be the one closest to the ends the axles slides in and since they are keyed to the housing only one side will show any wear , make sure there aren't any high spots and just flip it over .
Re: What Sure Grip Clutch Pack? [Re: bigsbigelow] #1314928
10/04/12 10:29 PM
10/04/12 10:29 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Buy the MP version from Mancini.
Re: What Sure Grip Clutch Pack? [Re: DoctorDiff] #1314929
10/04/12 11:21 PM
10/04/12 11:21 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
IIRC there was one kit out there that was too tight. And would chatter around corners. Something about the clutches were just a tad thicker then they should be.
